how to fix or changed this ?
Junkyard or honda for a new part. Sucks because I just trashed one a couple months ago. Could have given it to you. Look at wher it goes into the glass, there is a C clip and the hole part comes out of the glass.
This is what you need 73520-SH3-J10 LOCK ASSY., QUARTER $27.72 number 17
oh i see so you just pull out the C-clip it will off right ?
edited post above
yeah, remove the C clip and the whole part will come off. Remove the window from the car and lay it flat, the C clip is on there pretty good. Should be two philips screws holding the part to the lock assembly to the car.
No problem, get an extra set of hands when you remove and install the glass so you dont break it or scratch your paint. This is a super easy job once you get the window off the car.
no where in those 3 posts does he mention anything about it being EASIER IF you remove the window, he CLEARLY states to remove it dumbass...
RC000E
Aug 7, 2007 09:18 PM
