How big are the stock brake line nuts?
Old Sep 15, 2002 | 11:00 AM
FourthGenHatch's Avatar
Default How big are the stock brake line nuts?
My SS lines came with nuts to connect it to the hardline that are over 18mm. I was wondering how big the stock size is because I bought flare nut wrenches but they are not big enough to fit on the ss lines but if they will fit on the stock ones I will keep them and just get the other 18mm one...
Old Sep 15, 2002 | 11:16 AM
E-AT_me's Avatar
Default Re: How big are the stock brake line nuts? (FourthGenHatch)
the line wrenches you'll need is a 10mm. the other "nut" isn't that much a problem.. just throw a standard open-ended wrench on it..
Old Sep 15, 2002 | 11:32 AM
Default Re: How big are the stock brake line nuts? (Rexman)
Yeah I heard it was 10mm also. How come the ss line one is so much larger?
Old Sep 15, 2002 | 11:36 AM
91vtecripper's Avatar
when I got my ss lines the box said they were longer too.
Old Sep 15, 2002 | 11:38 AM
Default Re: How big are the stock brake line nuts? (91vtecripper)
I'm not talking about line length. I'm talking about the nut on the end of the line on the side that connects it to the hardline. The stock rubber hose has a 10mm one but these Goodridge lines have something at least 18mm.
Old Sep 15, 2002 | 11:41 AM
oh yeah my bad, I thought you ment length. Dont Know why I just used an opened end wrench.
Old Sep 15, 2002 | 11:44 AM
I think I will keep the flare nut wrenches and use it to get the brake lines off since they have been on for 14 years and I doubt they will come willingly. But can I just use an adjustable wrench to install the new lines? Or should I really use a line wrench?
Old Sep 15, 2002 | 03:51 PM
E-AT_me's Avatar
no, you don't understand.. there are 2 nuts on them.. one on the line, the braided, then a fitting on the "hard" line, on the car. the one on the hard line is a 10mm.. the other is on the braided/hose line itself.. this one doesn't matter that much, it doesn't strip out as much as the one on the hard line..
rexracerboy
Jul 20, 2007 08:23 PM
jvtec95
Aug 24, 2006 05:13 PM
Easy Eddy
Aug 18, 2006 01:16 PM
guymosiris
Jun 29, 2006 12:55 PM
ill phil
Aug 6, 2003 11:52 PM
