d16 stalls out
Old Jul 10, 2010 | 07:55 AM
Elitesky's Avatar
Default d16 stalls out
was running the p13 ecu with my d16z6 only problem was it was trying find an idle so i bought the correct ecu the p28 and after i plugged it in it runs fine.. until i let out of the gas and push the clutch in the idle goes down really low and sometimes stalls out...any suggestions?
thanks
Old Jul 10, 2010 | 12:42 PM
I CRX I's Avatar
Default Re: d16 stalls out
adjust the idle screw on the TB, check for CEL's, throttle cable could be loose as well.
Old Jul 10, 2010 | 01:23 PM
Icon_Ed6's Avatar
before adjusting the idle bleed screw... unplug iac, jump the 2-pin connector by the ecu (stops ecu from correcting the idle) THEN adjust the screw. When ur done, reconnect the iac, reset the ecu n ur good to go.
thehig
May 20, 2014 09:21 AM
thn116
Sep 2, 2007 06:48 PM
BeerBaron105
Jun 7, 2005 02:22 AM
blykins
Apr 30, 2004 03:35 AM
