HELP CODE 15
what up guys, well i made somewhat of a break through lastnight with my 4 door. i read the ECU flashes and they came out to a code 15 which is ignition output signal. Any help on this or advice would be helpful. i have looked at the wiring on the dizzy and the square connector had to wires very exposed and hanging by a thread. so i cut and re wired them and heat shrinked (the whole nine yards).
It can idle fine forever but once you drive it for like 5 minutes it starts to die out like theres little to no fuel, but i have changed out the fuel pump and everything. any help would be greatly appreciated
most likely coil or ignitor, did you reset the ecu after fixing the wires? try reset first. Also, check u whole ignition system, cap, rotor, wires etc... To save a lot of time, I jus swap dizzys real quick wit a known good one so I can see if its in the dizzy or if I need to move on to another component
keep an update if u figure it out
Blaze45
Jul 2, 2003 07:58 PM
