F/S 96 Honda odyssey A/C ICE COLD
Old Jul 9, 2010 | 02:54 PM
natedawg500's Avatar
Default F/S 96 Honda odyssey A/C ICE COLD
email : natedawg500@gmail.com
phone : 815 954-9019 call only if your serious.
96 Honda Odyssey - Red
ICE COLD A/C
224k miles
Fully rebuild motor/head/ rod bearings/ oil pump. at 218k. Uses no oil at all.
seats 7 comfortably
22-23city I got 27mpg on a trip from MI and back.
no check engine light
Up forsale is my daily driver/beater. I've put about 6k miles on this since last july never had one issue with it. I'm just looking for a car pref. a 96-00 civic coupe you got one maybe we could work out a deal.
-also have a accord 5spd trans/clutch if someone would be interested in 5spd swapping the wagovan. you would just need a shifter box/linkages and you should be golden. could throw in cheap.
-bad/needs
has some dents here n there- no terrible Honda rust though
-oil drips from the motor believe its the oil pressure sensor. something on the back of the block. not bad maybe add a 1/2 a qt. every 2500 miles. -but by that time is time for an oil change.
-suspension creaks from sitting for a long time at some point in its life.- put it on a rack or jack it up and lubricate it I'm sure it wont do it anymore.
I'm looking to get $1400 for it. It runs great. reliable and has ice cold a/c. what more could you ask for?
Old Jul 10, 2010 | 08:17 AM
The_Honda_Guy's Avatar
Default Re: F/S 96 Honda odyssey A/C ICE COLD
How about some more pictures! Heat work good? Could you for sure figure out where the oil is leaking from?
Old Jul 11, 2010 | 07:00 AM
i'll see if i can get more pictures. Heat works fantastic. Oil i dunno? somewhere on the upper part of the back of the block.
Old Jul 12, 2010 | 08:06 PM
If it's the oil sending unit that's no problem. I was just worried that with all the recent engine work something didn't get done right. Any other issues with it?
cdero
Jan 8, 2018 05:07 AM
orner
Sep 6, 2017 12:59 PM
jc164800
May 29, 2011 05:58 PM
Jrb599
Apr 21, 2011 02:00 PM
TX-Techman
Nov 12, 2009 08:26 PM
