Skunk2 Pro3 cams F/S BNIB!
Old Jul 9, 2010 | 01:03 PM
Turbo_sir's Avatar
Default Skunk2 Pro3 cams F/S BNIB!
I sold my all motor roller so i no longer have any use for these cams, They are still brand new in the box with all the paperwork and everything. I spent $750 on these about a year ago and would like $650 out of them(you dont have to worry about paying for shipping). They are the new design with the P3 stamped on end. These are the most badas$ cams you can get. Thanks for looking
INFO:
Exhaust Duration/Lift 276* / 12.0
Intake Duration/Lift 270* / 12.8
Skunk2 Pro-Series professional line of racing cams are designed to optimize mid-range and top-end HP and TQ; and significantly reduce lap times. VTEC crossover is seamless allowing for the broadest possible powerband. No other line of racing cams can even come close to the performance of the Pro-Series line.
Pro-Series [patent pending] camshaft profiles dramatically improve horsepower, torque, engine response, and valvetrain stability. The Pro1 cam is the BEST ALL-AROUND STREET CAM and dramatically improves horsepower, torque, engine response, and valvetrain stability. Pro-Series camshafts feature a seamless crossover between low and high speed cam lobes with [patent pending] profiles defined by specific lobe shapes as well as specific characteristics of lift, velocity, and acceleration. Pro-Series cams are all designed utilizing Skunk2’s proprietary Fast Ramp Technology and Amax Technology.
Use of these two technologies allows Skunk2 to design aggressive camshaft profiles that maximize area under the valve lift curve without adversely affecting valvetrain stability or reliability. In fact, the use of Fast Ramp and Amax Technologies actually makes Pro-Series camshafts more stable and less prone to spring surge at high rpms. Pro-Series camshafts also feature newly revised camshaft blanks that have increased torsional strength, improved durability characteristics, and reduced frictional effects; all of which are the reasons why Pro-Series camshafts are superior to all other cams
•Pro 3: Extreme Street/Race cam designed to optimize mid-range and top end HP and TQ. Peak power is increased and power band is moved 700rpm higher than Pro 2. No other high rpm racing cam can come close to the Pro 3. Pro-Series valvetrain required.
link to all specs here
http://shop.group5motorsport.com/i-56750.aspx
I can post a picture if it absolutely neccasary but I think we all know what cams look like, Like i said these are brand new in box!
Blazin Si
21
Jun 8, 2014 10:36 PM
coomplife05
Mar 8, 2013 07:21 PM
abusedvtec
Jul 3, 2010 10:00 AM
douglas_be
Dec 18, 2003 09:06 PM
