Compression numbers for a high mileage engine (FYI only)
Old Sep 15, 2002 | 09:47 AM
krshultz's Avatar
Default Compression numbers for a high mileage engine (FYI only)
Just providing a data point for people. 95 GS-R, 128K miles. 45 track weekends including wheel-to-wheel racing, and bunches of autocross runs. Uses probably 3/4 of a quart per track weekend. Compression numbers:
1: 225
2: 210
3: 225
4: 228
It's getting a little tired but certainly isn't terrible yet.
Old Sep 15, 2002 | 04:01 PM
Todd Reid's Avatar
Default Re: Compression numbers for a high mileage engine (krshultz)
da ubermoteur!!!!
lookin good, Shultz! I think you got the 1 in a thousand motor.....
Todd Reid
#11 H1 Honda Civic DX-LS
Old Sep 15, 2002 | 06:57 PM
Quick 200k Mile Motor's Avatar
keep it up man
keep oil in her.
I also have a high mileage motor near 200k miles (hence my nickname). Compression test was not accurate. So I did my own leakdown test...
Cyl#4 - 98.5%
Cyl#3 - 97.8%
Cyl#2 - 97.8%
Cyl#1 - 98.3%
Old Sep 23, 2002 | 04:07 PM
krshultz's Avatar
Default Re: Compression numbers for a high mileage engine (Quick 200k Mile Motor)
Yes yes, a leakdown test is on "the list." Those numbers look very good BTW.
Another data point from this past weekend (number 46):
- 2 drivers at an HPDE
- 130mph entering T1 (Roebling Road in Georgia)
- 3rd fastest time of the day (with codriver driving - I went off )
- Oil usage: 0.5 quarts
I feel like I should send a Thank You note to Honda.
Old Sep 24, 2002 | 04:45 AM
SJR's Avatar
SJR
speaking of leakdown tests.... I came across this link: http://www.lafishmag.com/LeakDownTester.html that shows how to build your own leak down tester.
I priced the parts:
Sears air line regulator: ~25$ (www.sears.com, part #00916025000)
Spark plug hose: ~$15 (powerhouseproducts.com, part #POW301013)
Coupler/nipple/teflon tape/etc.: $10 (Lowes)
Total: $50 - compared to a (nice) Longacre for ~$100, or a dealership charge of about $150...
hth.
Old Sep 24, 2002 | 06:34 AM
Tomakit's Avatar
Karl,
What kind of oil are you burning? regular or synthetic. cause if its synthetic then i *really* think that hoa should get a card this x-mas.
Tom
Old Sep 24, 2002 | 09:36 AM
krshultz's Avatar
Default Re: Compression numbers for a high mileage engine (Tomakit)
Mobil 1 5W-30 since 1000 miles. Up until recently I always used Honda oil filters - recently went to the Mobil 1 filters. I show up at every track event with fresh oil and a fresh filter, and have always done so.
SJR: Thanks much for that link. Gives me an excuse to go to the Sears at our pimpy new mall.
Old Sep 24, 2002 | 10:59 AM
SJR's Avatar
SJR
no problem Karl - anytime I can contribute to the addiction of a fellow man/woman and the shaking of his/her money tree...
Old Sep 25, 2002 | 04:11 PM
krshultz's Avatar
Default Re: Compression numbers for a high mileage engine (SJR)
Well, Sears had only a subset of the needed parts. Off to sears.com I go to spend still more money.
Old Sep 26, 2002 | 04:44 AM
SJR's Avatar
SJR
Default hmm....
so what did Sears not have? I was re-reading the how-to page, and the guy mentions ripping out the Schraeder valve. Hmm, is that necessary? 'cause if you leave the schraeder valve in it, then if you get a separate gauge (that goes higher than the one that comes with theh regulator) and hookup and bada-bing, you got yourself a compression tester. Of course, for $12, I guess you can just buy two of those adapter hoses - or you can make your own by using an old spark plug and gutting it - but that's really trying to be cheap
anyway, just rambling... and thinking that I have a 15 year old 6.9L diesel that could use a compression and leak-down test - except it ain't got no spark plugs! I guess I'd have to use the holes of the glow plugs... this is almost as much fun as getting on a track. (at least that's what i keep telling myself until the day I can go back to a track - sigh! jonesing sucks azz)
Old Sep 26, 2002 | 02:20 PM
Default Re: hmm.... (SJR)
Keep it simple. Go here..
http://www.g2ic.com/tegtips/engine/30.html
Although the author didnt know what the valve thingy was called, his write up makes it easier.
[Modified by Quick 200k Mile Motor, 6:20 PM 9/26/2002]
Boostin_GSR
May 23, 2007 01:12 PM
sdinteg
Feb 1, 2005 07:52 PM
Greenery18
Jul 6, 2004 08:29 AM
m0t0rhead
Feb 11, 2004 06:37 AM
speedymon
Jan 10, 2003 08:02 AM
