h22 accord transmission
Old Jul 8, 2010 | 08:57 PM
more3688's Avatar
Default h22 accord transmission
i have a h22 accord with the f22 transmission, it recently started grinding 3rd gear and i kept driving it......today i went out for a run in it and it started knocking really bad....what could cause a transmission knock besides loose flywheel or pressure plate, it still shifts into all gears....Could something inside the tranny gears have broke and be knocking....
It sounds similar to a rod knock but its coming from the transmission? any ideas?
Old Jul 8, 2010 | 10:52 PM
poid's Avatar
Default Re: h22 accord transmission
I've had a bearing let go before (mainshaft), could be that.
Old Jul 9, 2010 | 10:31 AM
extralargenog's Avatar
Broken diff pin.
Old Jul 9, 2010 | 12:26 PM
nus_dogg's Avatar
Either way, time for a H22 trans. Get a JDM F20B LSD trans, you won't regret. If you're nervous about bad gas mileage then go with an H23 trans or yet get a F22 trans which you can get the most MPG out of it.
Old Jul 9, 2010 | 01:19 PM
OBX LSD here for over 2 years taking over 650 WHP. Not 1 hiccup yet... I DID change the washers in the middle out though...
Old Jul 10, 2010 | 07:24 PM
slomofo's Avatar
GDD Member
I've been outta the game for a decade now, but is OBX good **** these days? Wow, I never thought I'd see that day come. When OBX LSD first hit the scene, nobody could remove their axles once they were installed.
Old Jul 10, 2010 | 08:14 PM
Peeonu25's Avatar
i hear theyre still not much better.
Old Jul 10, 2010 | 11:10 PM
nus_dogg's Avatar
Word.
Old Jul 11, 2010 | 09:59 AM
Im not syng theyre the BEST option, but I will say that with just a little work (Changing the bellievue washers in them) thyve taken 2-3 years of SEVERE abuse in my 3000 LB 650 WHP shitbox... Not 1 issue.
You believe everything you HEAR? There are 5 of us in your area having no issues AT ALL with them well north of 600whp.
Old Jul 11, 2010 | 12:40 PM
goldpearleg6's Avatar
i would have to say loose flywheel
2001GSRSC
Aug 15, 2017 12:07 PM
BOOSTWERKS
Mid-Atlantic (Sales)
Jul 1, 2008 05:31 PM
92egboost
12
Dec 3, 2006 04:19 AM
h22turbocivic4dr
Aug 5, 2004 08:41 PM
