4" exhaust in the EF chassis
Old Jul 7, 2010 | 10:18 PM
speeddave's Avatar
Default 4" exhaust in the EF chassis
Just curious to see if anybody has tried to shoe horn a 4" exhaust into the EF chassis following the same lines as factory?
I'm planning to build a new aluminum exhaust and still need to measure and test fit, but i thought i would see if there's anyone that has given it a shot?
Old Jul 7, 2010 | 10:24 PM
9bells's Avatar
OG Fabricator
Default Re: 4" exhaust in the EF chassis
I'm sure it's possible. Might need to get creative, and car will not be able to be 1" off the ground.
Just make sure to get various bend radii, it can make a world of difference.
If you really think it will be tight and bad clearance, aluminum is not a good choice really.
It will dent and scratch much easier. I've had to remove the factory shielding, take another route, etc.
Old Jul 8, 2010 | 04:54 AM
speeddave's Avatar
i think creativity will be key, the car is setup for its slick/skinnies combo so it does sit a bit higher then most lowered cars.
i've already moved most of the heat shielding for the previous exhaust i made (mild 3") the only part i am really worried about is over the rear lower control arm.
Old Jul 8, 2010 | 08:22 AM
sleepinonacreeper's Avatar
i've made a few 3" for that chassis and some 4" for other cars and dont see any problems with getting a 4" to fit under one. it would be way easier if it doesn't have a rear sway bar because you wouldn't have to go as high above the control arm.
Old Jul 8, 2010 | 06:29 PM
speeddave's Avatar
whats a good amount of space to leave above the control arm? i'm running the skunk2 drag coilovers movement is pretty minimal as is.
Old Jul 8, 2010 | 08:11 PM
HiProfile's Avatar
I made my own 3" for a sedan, and it fit over a 22mm rear sway w/o ever rattling or hitting anything. I used a 24" resonator in the stock possition too, which was ~5" outter diameter. If you just use a muffler in the rear and a stock rear sway (or none), you should be able to fit a 4" in the stock possition.
Split the difference, but hug the frame a little. Your frame won't move, the pipe will barely move, but your LCA moves quite a bit. The pipe will also move down from it's idle possition moreso than upwards.
I also recommend poly hangers, or the super-thick diesel exhaust hangers. I use the ones from autozone and they hold 5x the weight before sagging.
Old Jul 9, 2010 | 07:01 AM
hugging the frame rail is key for sure and so is good hangers and metal dowell that fits tight into them. use painters tape to mark your hub centerline (while suspension is compressed or move the tape up an inch and a half from where the hub normally sits) on the rear quarter. when you have the car lifted remove the rear strut and jack up the suspension to your marking point and that is you're clearance. i'll duct tape a paint stir stick where the control arm goes and put the strut back on. the closer you get to the frame rail the less the control arm will come up also.
Old Jul 11, 2010 | 09:34 PM
speeddave's Avatar
some good tips in here for sure, i'll update on the finished product.
thanks
OLDSKOOL89SI
Nov 9, 2009 12:15 PM
BxEF
Aug 17, 2008 04:01 AM
denraweb
Sep 1, 2007 09:08 PM
