Rear suspension squeaking / Grinding while turning
I have a '96 civic hatchback. Whenever I drive over minor bumps, my rear suspension would squeak. Also when I make slight-to-hard turns, I can hear something from the back grinding. What are the possible causes?
Could it be that the rear upper control arm bushings are out? Or the Rear trailing arm bushings are out?
trailing arm bushings are known to take a ****. u can replace them with OE from pepboys, or get the PWDJDM baller ones.
well, I would say to just do the RTA's but since you have it apart, check and see for yourself.. If its needs a bushing, then you know.
Rob.
11
Jul 8, 2012 07:13 PM
Lyonel 13H4
Aug 25, 2004 08:07 PM
RacerBoy
12
Apr 3, 2003 08:06 AM
rsx03
Oct 27, 2002 04:20 AM
