Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic EX OVERHEATING!! HELP?
Old Jul 7, 2010 | 07:29 PM
Tuanx2o9's Avatar
Default 2005 Civic EX OVERHEATING!! HELP?
Brand new radiator
timing belt changed last week
thermostat hose gets very hot, so i know it cant be thermostat
I see no visual leaks
can it be the water pump? but wouldnt i see leakage if it was?
not sure if its head gasket because there is no oil in coolant, overflow tank is fine.
Old Jul 7, 2010 | 09:18 PM
It Wasn't Me's Avatar
Default Re: 2005 Civic EX OVERHEATING!! HELP?
How many miles are on it?
What's the heater doing? Any loss of heat?
After you changed the radiator, did you thoroughly burp the system to remove all the air bubbles?
Old Jul 7, 2010 | 09:49 PM
Tuanx2o9's Avatar
about 140k
is there a way to bleed the air? i heard this year doesnt come with a bleed screw?
I havent checked the heater yet
Old Jul 7, 2010 | 09:56 PM
Tuanx2o9's Avatar
oh yea, both Fan works also.
Old Jul 7, 2010 | 10:05 PM
Tuanx2o9's Avatar
replaced the radiator because it was leaking causing the car to overheat, but now that the radiator is replaced, it overheated hours later down the road.
Old Jul 7, 2010 | 10:10 PM
Originally Posted by Tuanx2o9
about 140k
Did you change the water pump?
No, there is no bleed screw. I posted this in another thread, so rather than retyping it, I did the ol' copy-and-paste.
Buy one of these, it will help to thoroughly burp the system. You can probably find one locally, this is just a visual aid. (more or less)
http://www.tooltopia.com/search.aspx...Lisle+LIS24610
They attach to the radiator, like so ..
Keep it about half-full with coolant and (with the engine running) wait for the radiator fan to cycle a few times and/or until the bubbles no longer appear. Plug it, remove it, put your radiator cap on.. voila.
How bad did it overheat? Do you think there's a possibility that you warped the head and blew the gasket?
Old Jul 7, 2010 | 10:19 PM
Tuanx2o9's Avatar
I let it ran up to almost the "H" point then i shut off the engine and left the fan running to kool it down.
Old Jul 7, 2010 | 10:20 PM
Tuanx2o9's Avatar
no, water pump was not replaced.
im thinking its either i got air in the coolant system or a bad head gasket, but there is no symptom of a bad head gasket.
Old Jul 7, 2010 | 10:21 PM
Tuanx2o9's Avatar
its just that the first time it overheated, its because of the radiator. but now that its been taken care of, it still over heat later. only at a stop light or sign.
Old Jul 7, 2010 | 10:31 PM
It should have been replaced when you did the timing belt. Did you install a new belt tensioner when you replaced the timing belt? I hope so. . .
Other than the intermittent overheating?
Start with bleeding the system.
Are you losing any coolant? If you're losing coolant, and you don't have any visible leaks, then it can only be going into the motor.
Old Jul 7, 2010 | 10:44 PM
Tuanx2o9's Avatar
nope, i doubt that the tensioner was replaced.
nope, not losing any coolant.
imma start with the air bleed..everything else would of gave out clues, so im thinking there is air.
Old Jul 8, 2010 | 07:38 AM
EM2abe's Avatar
Is your coolant running high in your resevoir?
Old Jul 8, 2010 | 08:41 AM
Tuanx2o9's Avatar
nope, not at all..
Old Jul 8, 2010 | 09:38 AM
EM2abe's Avatar
Then I have no clue at all.
I'm having troubles as well, with over heating.
Old Jul 8, 2010 | 10:42 AM
Tuanx2o9's Avatar
okay i just got done with it..it end up being air bubbles from the radiator change. so i just bleed it now its fine.
Old Jul 8, 2010 | 01:23 PM
EM2abe's Avatar
How did you bleed the air bubbles out of it?
Old Jul 8, 2010 | 05:46 PM
Good to hear!
If you don't have one of the tools I listed, you can park on a slight incline (nose up) and just leave the radiator cap off. (or loosely on)
Then run the engine, wait for the fans to cycle a couple times or until there are no more bubbles. Keep the coolant topped off during this process.
Old Jul 12, 2010 | 11:02 AM
Tuanx2o9's Avatar
****...wtf now..??
okay new radiator, thermostat works, fan work, just bleed the coolant system and it stopped the overheating..
but 2 days later, the car overheated only when the a/c is on?
Old Jul 13, 2010 | 07:35 AM
Tuanx2o9's Avatar
anyone?
Old Jul 13, 2010 | 08:37 AM
EM2abe's Avatar
I'm really leaning on a warped head/bad head gasket.... It'll cost a lot, but I would get it checked... That's the last thing that you have left to do.. I'm currently in the process of that. Our radiators RARELY go bad, so im going all the way.
Old Jul 13, 2010 | 08:47 AM
chawski's Avatar
what kinda ballpark range are you looking at for a headgasket replacement? I realize the gasket doesnt cost much, but i cant imagine it being a saturday afternoon job either. I was quoted at around 1500.
Old Jul 13, 2010 | 12:01 PM
EM2abe's Avatar
Shouldnt really be more than a grand...
I was quoted around $900. If I provided all the parts, then $480 for labor only. Parts are coming out to around $282.
Old Jul 13, 2010 | 01:37 PM
[Edil]clyde's Avatar
i had the same problem with my 04 LX , checked everything and it turns out to be just the Fan switch. $22 from the local shop and replaced it on my own. Never had a problem again. Check if thats the problem.
to check if its the Fan switch , idle the car A/C off, if it overheats and the fan never went on, then its the fan switch.
Old Jul 13, 2010 | 02:05 PM
EM2abe's Avatar
@[Edi]clyde
****...wtf now..??
Old Jul 13, 2010 | 02:09 PM
@[Edi]clyde
probably only when A/C is on....
