advice when replacing front axle
93 civic del sol si
replacing front axles, anything that would be worth it and not too expensive to upgrade while replacing these?
are there any parts i will need other than the axles?
if you have the time and money, i would go ahead and change out the steering rack. they tend to leak out all of your power steering fluid after the seals get old. i would also go ahead and upgrade the suspension since you're already down there, if you want a better ride.
