Need Help! Car wont start
Old Jul 7, 2010 | 05:15 PM
Ghost Civic's Avatar
Default Need Help! Car wont start
Hey i have a 93 eg hatch with a d16 in it and it wont start. I checked to see if i have fuel and spark and came to the conclusion i have neither. The fuel pump does not come on at all. But i took a jumper wire from battery positive on the main relay connector and connected it straight to the fuel pump and it turned on. I checked the main relay and it is good. I even bought a brand new one. I am totally out of ideas and is wondering if anybody can help out.
Old Jul 7, 2010 | 05:24 PM
Former User's Avatar
Default Re: Need Help! Car wont start
Check whether fuse 31, 24, or 18 is blown.
Check whether the G101 ground wire attached to the thermostat housing is clean and tight.
Old Jul 7, 2010 | 05:28 PM
ttt
Old Jul 7, 2010 | 05:29 PM
I did have 2 blown fuses and i replaced them. I will check that ground and see whats up.
Old Jul 7, 2010 | 05:45 PM
Any CEL codes? Does the CEL stay on steady with the key in ON(II)?
Old Jul 7, 2010 | 06:10 PM
Yea it stays on. I know my ect sensor has 2 wires disconnected from it so idk if that can cause a no start too.
Old Jul 7, 2010 | 06:27 PM
No, a disconnected ECT sensor won't prevent a start. Jump the connector and pull the CEL codes. Does the CEL remain on steady after blinking code 6 or does code 6 just repeat?
Old Jul 8, 2010 | 04:58 PM
Burnt Toast's Avatar
Thread jack alert
My 00 em1 just died on me yesterday. I checked the maun relay and thought that was bad, so I went and bought a new one and installed it today. Still no go. I wnet through the diagnosit tests until I got to testing the fuel pump. I followed those instructions and jumped the 5 & 6 at the relay plug and didn't get any voltage at the fuel pump. The instructions tell me to check the groung for the fuel tank. What ground am I looking for?
Old Jul 11, 2010 | 06:34 PM
Im not sure on how to pull the codes. Where exactly are you suppose to jump?
Old Jul 11, 2010 | 06:53 PM
Check the forum sticky for pulling CEL codes.
Old Jul 15, 2010 | 01:41 PM
I tried changing oout my ecu and i wa getting fuel and spark but my car wouldnt start still.
Old Jul 15, 2010 | 01:44 PM
Check the mechanical timing.
Old Jul 15, 2010 | 01:57 PM
OK ill do that. Im not using the regular ecu. Im using a p75. Would that cause it not to start too because i heard somewhere that a p75 would allow it to run.
Old Jul 15, 2010 | 03:40 PM
Tico Loco's Avatar
Hi. Have you check your coil? If you have fuel, correct fuel presure, spark and timing belt is ok it should start. Sometimes a low coil may be tricky, spark should be almost white, not yellow and yes try with the original ecu first.
Old Jul 15, 2010 | 07:38 PM
Yea im tryin to find a p06 right now. Where is the coil located at?
Old Jul 18, 2010 | 10:02 AM
Thanks for the help everyone. I just got the car started yesterday. The timing was off alil bit and the spark plug wires were not in the right order.
Old Jul 25, 2010 | 03:37 PM
mmpg33's Avatar
[QUOTE=RonJ@HT;43035248]Check the mechanical timing.
Do you have a diagram for checking the timing on a DOHC B18C? I got a new distributor and it was giving me a CEL 4 for the crank angle sensor, it wants to start but sounds out of timing until the CEL comes in and then just cranks, any ideas?
Old Jul 25, 2010 | 05:08 PM
First fix CEL code 4 for the CKP sensor in the distributor.
Mechanical timing:
Old Jul 27, 2010 | 10:38 AM
mmpg33's Avatar
[QUOTE=RonJ@HT;43124411]First fix CEL code 4 for the CKP sensor in the distributor.
I have replaced the distributor and still have the code 4, I checked resistance of the sensor and it is aprox 360 ohms, I have yet to check if the wires from the connection to the distributor to the ECU. but if they are good, which i think they will be do you have any other ideas? Second question, about the timing, if the cam gears point up and match the TDC marks, and the crank pulley is off a bit, maybe 10 or 15 degrees, is there play in the pulley or is it keyed with the timing gear? thanks
Mershon
Old Jul 27, 2010 | 12:23 PM
There is probably a short or open in one of the two CKP sensor wires that run to the ECU. Check that first. If the wires are fine, however, you need to try swapping in a known good ECU.
Sounds like the mechanical timing may be off by a tooth.
Old Aug 4, 2010 | 02:07 PM
Tico Loco's Avatar
Hi, Yes a 10- 15 degree off is too much, your timing is off by one teeth. In some vehicles that can give you a crank angle code. Fix your timing first write us back.
fog raw
15
Nov 8, 2011 09:58 AM
jeephonda
Aug 23, 2010 11:08 AM
miguel329
Apr 11, 2009 04:42 AM
RDAYA0
Apr 10, 2008 12:55 PM
Formula Racing
Dec 18, 2005 07:28 PM
