koni gc ?
Running it like that is asking for failure. Only a taper end spring is supposed to be used on the Koni supplied spring perch (like an OEM spring). If you're using the Eibach springs that came with the GC sleeves, then they have a flat ground end intended for use on flat perches, such as what is on the GC sleeves.
Call GC and explain the situation. You probably only need the adapter rings to put non-Koni GC sleeves on a Koni shock, if they still offer them. Otherwise, you'll need either different shocks or different sleeves.
The silver spring perch included with the shocks sits on the circlip. There is no way to run them without the circlip.
And do NOT give out unsafe advice like this. Running a threaded sleeve such as GC sleeve on top of the silver spring perch is not safe, and the damage that can happen from doing so has been covered on this site several times.
Sigh.
was wondering, do you have the link for this? i was trying to look for it and all i found was circlip failure.
shpae
Dec 17, 2001 10:18 PM
