Stock seatbelt + Corbeau TRS Seats = ?
I was wondering if there is a way to get the stock seats belts to work with the Corbeau TRS seats. I've looked at the end with the lever and there aren't any bolts where I could put the seatbelt on. Is there any way I could put my stock seatbelts into use? Thanks.
If you look at your corbeau seat bracket/slider, there should be a extra hole on the seatbelt reciever side of each bracket. Take out the belt receiver from the OE seats and use the OE bolt to bolt on to the bracket..
that's how I did mine..
HTH,
J~
HTH,
J~
I like them a lot. They fit me perfectly. I am aboun 165-175 lbs and 5'8" if that helps. Its not too tight on the hips and perfect on my shoulders.
UNBRE4K4BLE
Nov 18, 2005 09:24 PM
