Easiest way to change a B18c starter
Old Jul 7, 2010 | 09:35 AM
paiger7208's Avatar
Icon2 Easiest way to change a B18c starter
Its located under the distributor and a coolent hose as well as my strut bar, so what would be the easiest way of going about replacing it?
Old Jul 7, 2010 | 10:04 AM
emotionisdead's Avatar
Very Emergency!!
Default Re: Easiest way to change a B18c starter
Disconnect you negative terminal in the battery, remove the strut brace, remove the air intake hose, drain the coolant, remove the upper and lower hose's from the block, remove the 12mm nut that attaching that positive wire to the starter, then remove the two 12mm bolts holding the starter in. It really is a 15min procedure.
I'm sure that you can do it without draining the coolant and removing the hoses, but I like to take a little extra time to remove sh*t that could possible get into the way and cause me a headache
Old Jul 7, 2010 | 11:42 AM
boarderfatty's Avatar
Honestly, all you really need to remove is the intake tube, the one 12mm nut off the starter sloenoid, and the one clip off the solenoid, the two 12mm that hold the starter in, and BAM. She's out.
No coolant, no mess. Though you may find it helpful to pull the harness back buy unclipping everyting on the pass side of the head and the reverse sensor on the front. Then just slide the harnessback out toward the back of the bay and you will have an easier time just fighting with the coolant hoses. I dont find the dizzy really gets in the way, but heck if you need to remove it, its only a few 12mm, a clip and some spark plug boots.
Old Jul 7, 2010 | 12:44 PM
chad's Avatar
Moderator
YOU ARE WRONG.....
you don't gotta drain nothing.....
disconnect neg battery
remove intake tube....
take 12mm nut off the positive side of starter
pull the neg clip
short extension with a 14mm get the top starter bolt off
long extension with 14mm get bottom start bolt off
unclip the wire harness
pull out (hahahah)
swap over wireharness brackets to new starter
repeat process in reverse to reinstall
Old Jul 7, 2010 | 03:25 PM
paiger7208's Avatar
Alright thanks everyone, you all have been extremely helpful! I would have spent a lot of time trying to remove things I wouldn't have needed so this will save me from that. Thanks again!
joenoreason
Dec 20, 2013 08:06 PM
B bOy CrAyOn
Aug 6, 2007 07:24 PM
WreckedTeggie
23
Dec 26, 2005 06:41 PM
mickey513
Mar 11, 2003 02:03 PM
randomwalk101
Jun 29, 2001 03:52 AM
