purging plugs
Old Jul 7, 2010 | 08:51 AM
russianvr4's Avatar
OG Fabricator
Default purging plugs
has anyone heard/tried http://purgeplugs.com/home.html ?
i just ordered their plug kit. this should beat using aluminum foil balled up and stuck into the end of the pipe :D
Old Jul 7, 2010 | 10:10 AM
9bells's Avatar
OG Fabricator
Default Re: purging plugs
Let me know how it goes. I use stainless wool, as it handles the very high temps that come with short sections near welds. If this stuff can handle 700-800 Degrees, then it will work.
Old Jul 7, 2010 | 11:21 AM
russianvr4's Avatar
OG Fabricator
from talking to the guys the sealing rings can handle 500* so they recommend welding 2-3 inches away from the plug. sealing rings are replaceable.
Old Jul 7, 2010 | 11:27 AM
weiRtech's Avatar
OG Fabricator
i just use cap plugs... cheap and simple.
Old Jul 7, 2010 | 01:04 PM
russianvr4's Avatar
OG Fabricator
cap plugs? mind expanding on that?
Old Jul 7, 2010 | 01:24 PM
Lee G's Avatar
I have access to a tube expander so I expand some stainless tube and weld up one end to make caps.
Old Jul 7, 2010 | 03:13 PM
weiRtech's Avatar
OG Fabricator
silicone cap plugs. they come in a wide variety of sizes. if one doesn't fit on the outside, a different size may fit on the inside. they also go well over oval shapes, or to fill rectangular turbo flange ports. i just punch a hole in one and feed the copper pipe from my purge setup through so it has a snug fit. i use them all the time and haven't melted one bad enough i had to throw it out yet... and if it does melt a bit, just let it cool down before you remove it and it won't leave any goo on your metal.
Old Jul 7, 2010 | 03:16 PM
russianvr4's Avatar
OG Fabricator
where do you buy those from?
Old Jul 7, 2010 | 03:48 PM
black0hatch's Avatar
what are those for?
Old Jul 7, 2010 | 04:06 PM
russianvr4's Avatar
OG Fabricator
um, for backpurging?
Old Jul 7, 2010 | 05:07 PM
weiRtech's Avatar
OG Fabricator
just google search cap plug. you should be able to get them at any industrial supply place.
Old Jul 7, 2010 | 05:08 PM
russianvr4's Avatar
OG Fabricator
thanks aaron!
Old Jul 8, 2010 | 08:28 PM
HiProfile's Avatar
In a pinch, or a really odd hole, you can use...TOAST!
Sounds funny, but it will fit any reasonable hole size/shape, seal well, and take lots of heat. The outside just gets crispy and eventually leaks a tad if too close to the weld.
Old Jul 8, 2010 | 08:29 PM
russianvr4's Avatar
OG Fabricator
you mean toasted bread?
Old Jul 9, 2010 | 06:29 PM
boostedblkef's Avatar
hahah
Old Jul 9, 2010 | 06:30 PM
russianvr4's Avatar
OG Fabricator
just got my set in, they look pretty nifty! gonna try them out next week when i start building the titanium header/exhaust on my bike.
Old Jul 9, 2010 | 07:47 PM
ALL IMPORT's Avatar
just pop a Biscuit in & it will swell to a perfect fit every time
Old Jul 19, 2010 | 09:34 PM
9bells's Avatar
OG Fabricator
Any feedback on the purge plugs yet? Interested to know what you think of them.
Old Jul 19, 2010 | 09:41 PM
russianvr4's Avatar
OG Fabricator
got the set in, looks pretty sweet. was going to weld some titanium that just came in and then i remembered that i filled up my 2nd 280 tank with helium because i gotta weld an assload of intercoolers... DOH.
i'll have to either pick up a 3rd tank tomorrow or wait untill i empty out the helium. fire dept already looked at me sideways with 2 280 tanks, wonder what they'll say when i get a 3rd LOL
crxb20ed
12
Oct 25, 2004 04:05 PM
NickGSR95
May 17, 2004 08:15 PM
Tommy_Gunns
Mar 10, 2002 02:17 PM
keys
Aug 8, 2001 07:52 AM
