b18b1 all motor build suggestion?
Old Jul 7, 2010 | 07:57 AM
demarEK_FTW's Avatar
Default b18b1 all motor build suggestion?
I picked up a b18b1 with 136k miles, was planning on doing a high compression N/A build,
was thinking about dropping some crower stage 2 cams in there as well as 81mm Nippon racing 11.57:1 pistons, and apr rod bolts,
from there i'm not sure what else i should do to get some extra power out of the block or head? any suggestions?
Old Jul 7, 2010 | 08:35 AM
fv8s's Avatar
Default Re: b18b1 all motor build suggestion?
porting the head will obviously help. maybe a thinner HG or milling the head to up your compression a little. the hytech rep also seems to be a popular for all motor builds along with a TB and decent flowing Intake manifold
Old Jul 8, 2010 | 12:00 AM
TR_Accord's Avatar
got some stage 3 crower cams and cam gears for sale for cheap. Gave it a good bit of power, just went boost. I would suggest them over stage 2's if your wanting to make power with an ls
Old Jul 8, 2010 | 07:10 AM
Do-Work's Avatar
What are your goals with this build
Old Jul 8, 2010 | 08:34 AM
i'm trying to make 180+ whp , was thinking about going with 84mm bore, and ycp pistons with npr rings,, and how much for the stage 3?
Old Jul 9, 2010 | 05:56 PM
TR_Accord's Avatar
with skunk2 adj. cam gears 350 shipped as long as your in the states
Old Jul 10, 2010 | 10:34 AM
nmssr08's Avatar
I built an all motor B18B before and I only got up to 165WHP. I had pretty much everything done to it as far as motor build (even blueprinted build) but again, this was over 4 years ago so I'm sure they have better parts to make better HP now.
I had high compression CP pistons (11.5:1), H-beam rods, knife edged crank, ported/polished head, crower valve/springs, crower stage 3 cams, adjustable cam gears, intake manifold, throttle body, etc..... I had an Apexi SAFC and got it professionally tuned..... results were little disappointing considering how much I spent.
I later went with an B18C VTEC head for LSVTEC setup and made 189.2WHP with port/polished head and ITR cams, crower valvetrains, Edelbrock manifold.
It depends on how much budget you have to spend on your engine build. I love N/A setup better than turbo. it's more fun to drive and less things to worry about. Good luck with your build man.
Joeygsr28
Mar 27, 2010 07:03 PM
levison
Nov 25, 2007 01:56 PM
TURBL0W
Nov 16, 2005 08:58 PM
94DOHCGsr
Nov 9, 2005 03:28 PM
c1civic
Nov 5, 2003 07:00 PM
