98-02 Accord Coupe Bulb Guide
Hi guys,
I've compiled the following information from around the interwebs, as most websites that do bulbs don't even know the sizes sometimes for bulbs on the Accord Coupe's 1998-2002 (UK - but should be the same in other markets):
Headlight (dipped/main) - HB4/9006
Headlight (high beam) - HB3/9005
Sidelights - W5W - 501
Front Indicator - PY21W - 1158 - 581 - BAU15S AMBER
Reversing Lamp - P21W
Stop/Tail Lamp - P21/5W - 1157 - 380 - BAY15D
Rear Fog Lamp - P21W
Rear Indicator - P21W
DETAIL
Parking Light Bulb Size:
#1157NALL NATURAL AMBER LONG LIFE MINIATURE BULB BAY15D BASE - 12.8/14.0 Volt 2.1/0.59 Amp Natural Amber S8 Double Contact (DC) Index Bayonet (BAY15d) Base. 24/2.2 MSCP, C-6 Filament Design. 2,000/10,000 Average Rated Hours, 2.00" Maximum Overall Length.
Front Turn Signal Light Bulb Size:
Rear Turn Signal Light Bulb Size:
#3057A AMBER MINIATURE BULB PLASTIC WEDGE BASE - 12.8/14.0 Volt 2.1/0.48 Amp Painted Amber S-8, Plastic Wedge Base, 24 MSCP C-6/C-6 Filament Design, 2.09" Maximum Overall Length,
Tail Light Bulb Size:
#3057 MINIATURE BULB PLASTIC WEDGE BASE - 12.8/14.0 Volt 2.1/0.48 Amp S-8, Plastic Wedge Base, 32 MSCP C-6/C-6 Filament Design, 2.09" Maximum Overall Length, 1,200/5,000 Average Rated Hours.
Stop Light Bulb Size:
High Mount Stop Light Bulb Size:
#7440 MINIATURE BULB GLASS WEDGE BASE - 13.5 Volt 1.85 Amp T-6 Glass Wedge Base, 37 MSCP, C-6 Filament Design. 300 Average Rated Hours, 1.75" Average Overall Length
License Plate Light Bulb Size:
#168 MINIATURE BULB GLASS WEDGE BASE - 14 Volt .35 Amp T3-1/4 Glass Wedge Base Miniature Bulb, 3.0 MSCP C-2F Filament Design, 1,500 Average Rated Hours. 1.06" Maximum Overall Length.
Back Up Light Bulb Size:
Front Side Marker Light Bulb Size:
Rear Sidemarker Light Bulb Size:
Ash Tray Light Bulb Size: 74
Map Light Bulb Size:
Dome Light Bulb Size:
6418 - MINIATURE BULB SV8.5MM BASE - 12.0 Volt 0.4 Amp 10MM Festoon 4.8 Watt SV8.5mm Base, C-8 Filament Design, 3.58 MSCP. 350 Average Rated Hours, 1.38" Average Overall Length.
Step/Courtesy Light Bulb Size:
Trunk/Cargo Area Light Bulb Size:
Hope that helps someone!
d
DETAIL
d
2002 Honda Accord Coupe Light Bulb Socket Sizes
Just to confirm further sizes check thsi out....
Low Beam Headlamp Light Bulb Size: 9006 or 9006 HID Upgrade Kit
High Beam Headlamp Light Bulb Size: 9005 or 9005 HID Upgrade Kit
Parking Light Bulb Size: 1157A or 168
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 7440
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: 7440
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 7440
Front Side Marker Light Bulb Size: 1157A
Rear Side Marker Light Bulb Size: 168
Map Light Bulb Size: 168
Dome Light Bulb Size: DE3423
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 168
The 2002 Honda Accord Coupe light bulb socket size and lightbulb replacement information above is updated as it is submitted by the Modified Life community.
Fabulous List !
I get my Bulbs at a great price in the UK for my US Accord 3.0 V6 from:
HONDA (US) ACCORD (1990 - 1998) Car Headlight Bulbs | PowerBulbs.
Does anyone know the wire/pin configuration for the OBDii socket - only I have to replace the odd plug there now, with a standard 16pin and the workshop manual does not specify the pin designation and wire colour...
Dave
Dave
krustin
May 27, 2013 04:48 AM
