Reusing Head bolts d16a6..torque spec?
Old Jul 6, 2010 | 09:43 PM
91CrxMann's Avatar
Default Reusing Head bolts d16a6..torque spec?
i torqued my head down to 48ft lbs of torque.. i only have 125 psi per cylinder right now and the car will not run.. can i torqque them down more ? i am reusing a metal gasket as well, i hit both sides with copper spray... anyone got an idea
Old Jul 6, 2010 | 09:55 PM
pearl95sc's Avatar
Default Re: Reusing Head bolts d16a6..torque spec?
Not to sound negative............but are you serious? Re-Using a HEAD GASKET? Re-using the head bolts is bad enough, and while many do it and things work okay, they are Torque To Yeild, meaning they stretch. So yeah, you'll need to torque em down a lil more, maybe like 5-6 additional ft. lbs. Also do them in steps, half torque amount first, then the full amount.
But re-using the HEAD GASKET? Even a cheapo ebay no name gasket is only what, like 20-30$ shipped? Good luck man, I've done some pretty good ghetto fabulous things before, but this takes the cake.
Old Jul 6, 2010 | 10:04 PM
91CrxMann's Avatar
the head gasket has 2 miles on it and is metal. ill just torque the **** out of them
Old Jul 6, 2010 | 10:08 PM
pearl95sc's Avatar
If it didn't seat yeat and hasn't been heat cycled, that's a different story. Don't over torque, don't wanna snap one of them bolts. Are you sure the gasket is the problem and not a valve seal or ring? The motor should run with anything over 120ish across the board. Albeit a bit low, its do able.
Old Jul 6, 2010 | 10:49 PM
91CrxMann's Avatar
i just cleaned all the valves and lapped them, they got nice smooth seal. i was told i need like 150 to run..i dunno
Old Jul 6, 2010 | 11:15 PM
TJChad's Avatar
Yep, just torque the holy hell out of them......you'll be good to go then.............
Old Jul 7, 2010 | 12:38 PM
CRXSIPower's Avatar
I'd be a little scared over tourqing used head bolts, go in small increments if you do.
Old Jul 7, 2010 | 12:41 PM
EsotericImage's Avatar
Retired Moderator
^^^^^ +1
the only ones u can re-use are ARP's
Old Jul 7, 2010 | 01:06 PM
D16SiHatch's Avatar
low psi across the board would make me think you have a mechanical timing issue
Old Jul 7, 2010 | 01:58 PM
Jaime 91SiB18's Avatar
Old Jul 7, 2010 | 02:04 PM
91CrxMann's Avatar
going to torque them down.. let ya know wat happens
Old Jul 7, 2010 | 02:41 PM
TJChad's Avatar
Have you even tried a wet compression test?
Old Jul 7, 2010 | 05:30 PM
Tyson's Avatar
idea 1: dont reuse your head gasket.
idea 2: dont reuse the original head bolts. at least reuse 92+ D series bolts which are meant to be reused.
idea 3: dont ask for ideas and ignore it.
Old Jul 7, 2010 | 05:42 PM
fireant's Avatar
Get a new head gasket and try again. If you still have problems, you'll need new bolts.
Old Jul 8, 2010 | 07:26 AM
91CrxMann's Avatar
read the whole post before u judge... and the bolt are reusable up to 3 or 4 times...
Old Jul 8, 2010 | 09:02 AM
Tyson's Avatar
you mean judge this? lol.
reusable 3 or 4 times??!! you fail as a mechanic.
educate yourself.
http://www.hondaworkshop.com/misc/97-047TSB.jpg
Old Jul 8, 2010 | 09:58 AM
lunalink's Avatar
^ ha ha PWNED!
Old Jul 8, 2010 | 10:03 AM
TJChad's Avatar
I agree with the post below this one, TTY bolts are re-usable ONCE. Even though it's not good practice they are allowed to be re used ONCE. However most GOOD technicians will replace them because they're generally not that ones that have been under your hood and have no way of knowing if that have already been re used once or not. But 3-4.......please do some more research and learning.
Old Jul 8, 2010 | 10:06 AM
TJChad's Avatar
Also, I just looked up above, what was it you sprayed on the gasket, and why did you put anything on it?
Old Jul 8, 2010 | 01:47 PM
91CrxMann's Avatar
copper gasket spray adhesive
Old Jul 8, 2010 | 03:18 PM
89civicdx's Avatar
You aren't supposed to but you can re use the metal gaskets , I re used one 2 times! no problems just clean it and spray it with permatex copper spray.
This stuff is fantastic
http://www.permatex.com/products/aut...ve_Sealant.htm
And I've never bought new head bolts lol re use them!
it should run on 125 maybe the timing is off does it sound like its trying to start?
Old Jul 8, 2010 | 05:33 PM
91CrxMann's Avatar
it wants to start..maybe i get it to kick over once then nothing.. new battery and stuff too... going to get new gasket and try again
Old Jul 8, 2010 | 08:54 PM
LamEF's Avatar
CHECK THE TIMING THRICE MORE TIMES!
If you need to over tighten, you've done something wrong. with copper spray on there, it will certainly hold 150 for now. If it was the gasket or piston rings then pressure would be uneven across the cylinders. if its consistent across all 4 cylinders you probably have a valve/timing issue to address.
Old Jul 9, 2010 | 08:15 PM
91CrxMann's Avatar
how can i check timing...
Old Jul 9, 2010 | 08:39 PM
dacrxguy's Avatar
wow op you best be trolling because if you are not then op i feel sorry for you
op i think you messed up your motor when you laped your valves. the only way to tell if you have low compression is to do a leakdown test
