tach jumping
Old Sep 15, 2002 | 01:27 AM
dragonrcr's Avatar
Default tach jumping
i have a auto meter, monster tach, my shift light is set to go at 8000 rpm's it gets to about 7500 and all the sudden it freaks out and jumps up and down it is wired into my msd ignition so its not like it is wired in wrong does anyone have any suggestions.
Old Sep 15, 2002 | 01:59 AM
ninesecrx's Avatar
Default Re: tach jumping (dragonrcr)
it might be getting a funky cross signal from something else. Also ive seen distrubtors go bad and the tach will go haywire like that...
Old Sep 15, 2002 | 08:07 AM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: tach jumping (ninesecrx)
you can try replacing your igniter, thats what usually makes the tacks go crazy towards high rpm.
Old Sep 15, 2002 | 08:25 AM
Maxi's Avatar
Default Re: tach jumping (mannyman)
my tach was doing this because of a distributor problem. I think the main bearing had gone dry. Lots of brown dust in the distributor cap. I tried swapping in a different ignitor but that didn't solve the problem for me. I had to get the distributor rebuilt before the bad tach reading was gone. I assume at this point the bearing was seizing, but a bad ignitor or bad wiring could cause your jumpy tach. If you pull the cap off your rotor and see lots of brown dust, means your main bearing is dry and it's the likely source of your woes.
[Modified by Maxi, 9:26 AM 9/15/2002]
Old Sep 15, 2002 | 01:36 PM
speedymon's Avatar
Default Re: tach jumping (Maxi)
I had the same problem. I just replaced to distro.
Old Sep 17, 2002 | 03:16 PM
DaiJekBok's Avatar
Had the same problem in my GS-R. Ignitor was replaced (under warranty.. yay!) and the problem went away.
hondacivic90zc
12
Jul 3, 2009 08:57 AM
crxb16ftw
Jun 20, 2007 12:02 PM
Apd3111
Jan 4, 2006 02:45 PM
De_tour
Dec 15, 2005 06:59 PM
WhiteEG6
May 25, 2004 09:51 AM
