00 civic electrical problems....CEL no code
Old Jul 6, 2010 | 04:19 AM
Nichelson_Performance's Avatar
Default 00 civic electrical problems....CEL no code
Well I was driving to work this morning and all the sudden the CEL came on and the engine was acting up, luckily I made it to work....I jumped the blue connector out but no flashes just a steady light .....about a month ago I went on a cruise and it ended up with flood type rains and I had to drive home in it....this reminds me of a problem my brother had with his 2000 civic and it ended up being the ground connectors in the main wire harness so this is leaving me to believe I'm having the same problem
Does anyone have a suggestions?
Thanks
Old Jul 6, 2010 | 06:01 AM
Former User's Avatar
Default Re: 00 civic electrical problems....CEL no code
Is the 7.5A hood Back Up fuse blown?
Also take the car to an auto parts store to see whether the code can be pulled with an OBDII scan tool.
Old Jul 6, 2010 | 06:55 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Yep.
Your 2000 is an OBD2b car, which means you can use a scan tool and get a much more precise trouble code than you could by using the blink method.
Autozone and similar parts stores will let you use theirs for free. It plugs in under the dash next to the fusebox.
Old Jul 6, 2010 | 07:21 AM
I forgot to mention I'm converted to obd1 with a chrome tuned p28
erupt323
12
Mar 18, 2014 12:34 AM
jman831
Aug 9, 2012 08:40 AM
rogha
May 4, 2010 08:50 AM
ReggieGrip
Feb 21, 2006 05:00 PM
huffer427
Jun 4, 2004 10:48 AM
