when does your rpm get fuel cut off?
Old Sep 14, 2002 | 11:25 PM
itr1244's Avatar
Default when does your rpm get fuel cut off?
mine only can go up to just 8400
never cant go over a dot on a redline~
i hear some say they can go up to 9k
anything wrong with mine? or it's just normal?
and my itr's 01
Old Sep 14, 2002 | 11:26 PM
TypeR 599's Avatar
Default Re: when does your rpm get fuel cut off? (itr1244)
my tach is off, fuel cuts off at around 8,900 on my car.
Old Sep 14, 2002 | 11:28 PM
itr1244's Avatar
Default Re: when does your rpm get fuel cut off? (TypeR 599)
that's nice though~ ^^
Old Sep 14, 2002 | 11:29 PM
Bbasso's Avatar
my tach is rather acurate vtec hits at 5700 and my fuel cut off is at 9100- go figure
Old Sep 14, 2002 | 11:30 PM
itr1244's Avatar
Default Re: when does your rpm get fuel cut off? (Bbasso)
how the Fxxx? 9100?? damn
my vtec comes in right on 5700 but tops out right on 8400
B2FiNiTY's Avatar
Should be around 8600 I believe.
Old Sep 14, 2002 | 11:31 PM
itr1244's Avatar
Default Re: when does your rpm get fuel cut off? (B2FiNiTY)
what's wrong with mine~
anything i can do about this?
Old Sep 14, 2002 | 11:34 PM
TypeR 599's Avatar
dont worry, tons of people on this board said their tachs are off. it's fine, just know when it is and shift before it.
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
On the dyno mine hit fuel cut at 8,590 with the tach registering around 8,800rpms. VTEC engagement varies between 5.6-5.8k.
Old Sep 14, 2002 | 11:37 PM
Type-Rare#1248's Avatar
i believe the 2001 R's are more accurate...cuz mine begins at 5700 and shuts off at 8500
Old Sep 14, 2002 | 11:38 PM
B2FiNiTY's Avatar
Default Re: when does your rpm get fuel cut off? (Type-Rare#1248)
Not really.
'01 ITR - vtec 6k - cutoff 9100-9200
Old Sep 14, 2002 | 11:39 PM
itr1244's Avatar
12450 posts man~ that's nuts
how long have u been in this board B2FiNiTY?
Old Sep 14, 2002 | 11:40 PM
TypeR 599's Avatar
12451 posts (22.27 posts per day on average)
no one can touch that...
Old Sep 14, 2002 | 11:41 PM
B2FiNiTY's Avatar
B2FiNiTY has been a member for 558 days.
Happy member for almost 2 years.
Old Sep 14, 2002 | 11:45 PM
itr1244's Avatar
holly chit
good job man~
Old Sep 14, 2002 | 11:46 PM
TypeR 599's Avatar
i really wouldn't congratulate that...just call him a post ***** and move on
Old Sep 15, 2002 | 01:03 AM
SoCal ITR's Avatar
ITR tach's are always off. You can get it calibrated, but it doesn't really matter. Fuel cut-off is at around 8650 rpm, actual, not indicated....
My tach is actually pretty acurate. You can test it by (after your car is warmed up...) hit the gas and tap the rev limiter... that's how I figured out where mine was, indicated at least.
Old Sep 15, 2002 | 07:17 AM
uNF$@#!'s Avatar
Default Re: when does your rpm get fuel cut off? (ActiveAero Ninja Edition)
engagement = 5900, shutoff = 5600.
Old Sep 15, 2002 | 07:24 AM
Dave-ROR's Avatar
IIRC, VTEC engagement is 5700 and fuel cut activates at 8500. It doesn't matter what your tach say as it's not important. It your's his fuel cut at 8400 indicated then shift right before then, if it says 10k for 8500ish then shift just before that. The one displaying 10k will not be faster.
Old Sep 15, 2002 | 07:25 AM
Dave-ROR's Avatar
Default Re: when does your rpm get fuel cut off? (Soup ****)
[sarcasm]y0 j00 never hit VTECH y0![/sarcasm]
-Dave, who misspelled on purpose.
Old Sep 15, 2002 | 07:41 AM
98R-1144's Avatar
Default Re: when does your rpm get fuel cut off? (SoFreshAndSoCleanClean)
this might be a dumb Q, but how do you know when fuel cutoff occurs? do you feel just a sudden loss of power --- or can you tell from a dyno?
Old Sep 15, 2002 | 07:47 AM
Dave-ROR's Avatar
Default Re: when does your rpm get fuel cut off? (98R-1144)
Like George said you'd notice it. To see for yourself just keep it floored in second on some 60mphish speedlimit road until you here it.. and you'll hear it
Old Sep 15, 2002 | 08:18 AM
B2FiNiTY's Avatar
I truely believe it gets cut off at 8600 because I have hit 85XX and that's with my vafc on hold for peak RPM.
Old Sep 15, 2002 | 08:28 AM
jond's Avatar
I have a video of a ITR bouncing the rev limiter in 5th gear! Have you guys seen it. I think one of the mods wants to suppress it.
[Modified by jond, 12:29 PM 9/15/2002]
Old Sep 15, 2002 | 09:19 AM
yellow blur's Avatar
Default Re: when does your rpm get fuel cut off? (jond)
I can bury my needle at ~9200 before it'll hit fuel cutoff.
