Wiring Problems?
Old Jul 5, 2010 | 09:17 PM
sliiiiced's Avatar
Default Wiring Problems?
Hello, I am in the midst of doing a b20vtec swap into my 1991 CRX DX and i need to know what kind of wiring situation. Will it be the normal dpfi to mpfi conversion or is it a matter of buying a jumper harness?
Sorry for the stupidity, Thank you for the answers!
Old Jul 5, 2010 | 09:47 PM
D16SiHatch's Avatar
Default Re: Wiring Problems?
you will need to convert to mpfi and also to obd1. these are 2 seperate things so do the mpfi first and then get the jumper,etc that you need for the obd1 conversion.
Old Jul 5, 2010 | 10:06 PM
sliiiiced's Avatar
okay so ill convert it to mpfi, remove the engine, the whatever i need to convert it to OBD1? Im thinking its just the jumper harness right?
Old Jul 6, 2010 | 09:17 AM
sliiiiced's Avatar
reassurance would be lovely
Old Jul 6, 2010 | 03:55 PM
D16SiHatch's Avatar
you need the jumper harness yes, but then you also need to run the subharness wires/connectors into the engine bay and hook them up for vtec, 4 wire o2, etc. then you also need to run an obd1 distributor. you can keep peak/hold injectors if you retain the resistor box, otherwise delete the box and run saturated injectors.
Old Jul 6, 2010 | 04:54 PM
2poor2tune's Avatar
might as well tuck it while your at it
Old Jul 7, 2010 | 07:50 PM
sliiiiced's Avatar
i may tuck it i may not, but if i dont tuck it ill make for damn sure i dont have it lookin all ghetto with wires hanging every where! thanks for the help!
Rorohohoo
Dec 23, 2015 10:13 AM
ed3jose
Jun 10, 2015 04:29 PM
Homotor
Oct 18, 2010 08:37 AM
mahatma
Jun 4, 2006 07:30 AM
Patch
Feb 29, 2004 07:21 PM
