97 civic hatch swap problem
Old Jul 5, 2010 | 04:23 PM
jdm itr integra's Avatar
Default 97 civic hatch swap problem
i got a 97 dx ek hatch that i recently put a gsr swap and will like to know what vtec motor harness i could use. try using the old one from my car but the idle sensor has 3 wires and b series only two. WHAT HARNESS WILL FIT THAT IS VTEC PREWIRE FROM EX COUPE? AND WILL THERE BE MODIFICATIONS TO DO FOR IT TO WORK THANK YOU
Old Jul 5, 2010 | 04:28 PM
94EG8's Avatar
Seagull Management
Default Re: 97 civic hatch swap problem
5 speed '96 - '98 EX harness requires the least amount of modification, you will need to add the IAB wiring and extend a few wires to reach certain sensors.
Old Jul 5, 2010 | 04:42 PM
i bought a 97 ex harness but one of the plug that goes to the ecu is bigger, all the plugs the same as my old harness except one. will it work if i buy a jumper harness for the ex harness
Old Jul 5, 2010 | 04:52 PM
94EG8's Avatar
Seagull Management
EX uses the same ECU plugs, i'm assuming you didn't actually end up with a '96 - '98 harness, post pics of the ECU plugs.
Old Jul 5, 2010 | 04:58 PM
the new harness that i got wont fit on the single cam computer, but the automatic ex harness fits on it will post pictures later on
Old Jul 5, 2010 | 11:16 PM
civicej6's Avatar
You should just look for a gsr harness it will be alot more easier
Old Jul 6, 2010 | 11:34 AM
pakn-heat's Avatar
dont think you can use gsr harness on 96+civic.
96-98 civic ex/dx/lx harnesses should be the same at the ecu plugs.
and i think you can just cut one wire off the 3 wire and run it like that.
might have to use the plug for the gsr one.and just splice wires.leave that one wire unhooked, if it dont plug in.
are you trying to use your original civic ecu?
was you car automatic before?
Old Jul 6, 2010 | 01:24 PM
94EG8's Avatar
Seagull Management
Theres your problem, if you use an automatic EX harness the only real advantage is that vtec is prewired, you still have to convert the harness for a 2 wire IACV. 5 speed EX harnesses are already setup for a 2 wire IACV.
Old Jul 6, 2010 | 03:09 PM
my car is originally 5 speed and im going to use a chip ecu so dont need o2 sensor and others, i had bought a jumper harness that fitted on my original harness but the 97 civic ex harness that i just bought the plugs fit except one, the only harness that fits perfect on original sohc ecu and jumper harness its the automatic. if i get the right jumper harness for that ex harness will it work properly?
Old Apr 2, 2011 | 11:56 AM
96ekb16's Avatar
i got the same prob 96 civic b16 i need a obd2a harness 5 speed i found one but its auto will it work ???
brentl21
Engine Management and Tuning
Feb 19, 2016 07:57 AM
CHAMPwhteEK
Jun 15, 2011 01:07 PM
Lil Rick
Jan 27, 2011 10:08 PM
PatrickGSR94
Aug 13, 2003 03:44 PM
boostedcivicsir
16
May 9, 2003 09:58 PM
