BESTBUY F*CK UP-----DEI 508d Proximity on Viper 5901 Alarm
So I had the 5901 Viper installed, as well as other components. One of them being the DEI 508d Proximity. They told me that they cant wire up BOTH proximities, warn away and full alarm.
WTF.
So now if someone walks up to my car, the full siren goes off.
How can I get this wired correctly?
WTF.
((((((((((((Optional sensor port - 4-pin connector))))))))))))))
There is a shock sensor built onboard the main unit. This connector is an optional
sensor port to add sensors to the security system. Optional sensors that may be
used are: 508D Doubleguard Proximity Field Disturbance, 509U Ultrasonic
Sensor, 506T Glass Break Sensor, and 507M Digital Tilt Sensor.
This input can also be used for a second 504D Doubleguard Shock Sensor, or
for additional pin and magnetic switches.
Page 28 of install guide. 94
Backup batteries don't use a port. They have a single trigger output.
They just need to adjust the sensitivity. The signal for both warn and full trigger is on the same wire.
Ditto, the BB should not be on that port, BB trigger should be wired to hood pin switch input.
The extra sensor input has both the warn a way and full alarming trigger input, along with power and ground. 94
weekendboost
Audio / Security / Video
Dec 11, 2017 02:59 AM
Bad_dude
14
Jul 1, 2012 07:49 PM
Undepelo
22
Sep 26, 2002 05:51 PM
