Need help finding parking lights
Old Jul 3, 2010 | 07:22 PM
surrealx's Avatar
Default Need help finding parking lights
So I'm hooking up a keyless entry in my 4dr integra. I have hooked up everything else already (lock, unlock, etc...) I'm having trouble finding where the parking light is. I went on Causeforalarm v7 and it says the parking light is a red/black wire and then there's another one where they said on the fuse panel theres the 4th plug. On the main connector I know the parking light is the White wire so I don't know where to plug it. I put it in the 4th plug on the fuse panel but the lights don't flash.
It is a Viper 5301
Thank you.
Old Jul 4, 2010 | 10:52 AM
surrealx's Avatar
Default Re: Need help finding parking lights
ttt
Old Jul 5, 2010 | 12:35 AM
surrealx's Avatar
ttt
Old Jul 5, 2010 | 05:53 PM
fcm's Avatar
fcm
Old Fart
Parking light "free pin", [4th plug????] on fuse box, sounds like you have the wrong free pin, test them, the one that goes to 12V+ when you turn on the park/head lights is the correct one, you will also find a 12V constant free pin, [hot at all times] and a 2nd ign. free pin, [hot in run only]
What year is your Integra? 94
Old Jul 5, 2010 | 09:37 PM
surrealx's Avatar
It's a 97 4dr ls sedan. So on the connector of the Viper 5301 I know the white wire is the parking light. I just need to know where to put that wire to make the lights flash when I lock or unlock. Is there any other wire on the module that would need to be connected to something else?
Old Jul 6, 2010 | 06:13 AM
fcm's Avatar
fcm
Old Fart
There is no other wire that needs connecting.
Make sure the park light polarity jumper is in the correct location, [pos. (+) output].
Make sure you have the correct free pin on the fuse box. 94
Old Jul 6, 2010 | 12:07 PM
surrealx's Avatar
Ok. I will look over the module to see if there's a polarity jumper and try some different fuse box positions. Thanks
Old Jul 6, 2010 | 03:20 PM
surrealx's Avatar
I tried all the slots on the fuse panels under the dash. None of it worked. I changed a jumper and still no luck. Is there suppose to be a inline fuse?
Old Jul 6, 2010 | 05:05 PM
fcm's Avatar
fcm
Old Fart
Do you not have a meter or test light? 94
Old Jul 6, 2010 | 09:39 PM
surrealx's Avatar
I have a test light. I should hook up the test light to that white wire and try to see if it lights up correct?
Old Jul 7, 2010 | 04:50 PM
fcm's Avatar
fcm
Old Fart
first test the free pins to make sure you have the correct one, if you do, then test the output from the alarm. 94
bradtricker
Audio / Security / Video
Nov 4, 2008 07:09 PM
honda06si
Honda Civic (2006 - 2015)
Oct 9, 2006 12:48 PM
Hybrid 350GT
Sep 22, 2006 07:33 PM
BrainzIRL
10
Feb 22, 2006 12:20 PM
