None of my gauges work
Which fuse controls the gauges? I switched out my main relay with another one in my 93 accord lx and then i noticed the clock and all the gauges stopped working. I know its one of the fuses by the dashboard but do you have any idea which one?
Until someone comes in to give you a picture, you are going to have to check all of them, it only takes 5 minutes, pull them out one at a time and make sure you put them back in the same hole. Do you not have a test light to touch the two test points on the back of the fuse to see if you have power to both sides.
You also may have broken a wire under the dash, changing the main relay should not have blown a fuse. How did you gain access to your main relay, I guess if we knew that, it would help a little.
Does your fuse box cover not have a slot marked GAUGES???
frizzo
11
Jul 22, 2007 10:02 PM
hans stoner
Oct 2, 2006 06:11 AM
