Transmission & Drivetrain Gearboxes, Differentials, Clutches
Axle will not clip into transmission... Literally tried almost everything.
Old Jul 5, 2010 | 01:54 PM
DiscoLemonade's Avatar
Default Axle will not clip into transmission... Literally tried almost everything.
My axle will not clip into the transmission. It will go all the way in but comes out as easily as it goes in, I have made the clip on the end smaller, i have made it wider, I have gotten new clips put on it, I have faced the opening of the clip downwards, upwards, I have used plenty of force to try to get the clip to engage, I've replaced the axle seal, I feel like I have tried everything known to man, nothing works please help, and the axle and all of the splines are in good shape.
Old Jul 5, 2010 | 08:06 PM
lahiena's Avatar
Default Re: Axle will not clip into transmission... Literally tried almost everything.
just put the car in neutral spin the axle and push it at the same time that how i did it on my integra
Old Jul 5, 2010 | 09:05 PM
Yea.. I've done that. I've tried all the gears spinning it I have been at this for days.
Old Jul 6, 2010 | 01:26 PM
David @ Synchrotech's Avatar
Look inside the differential and see if the area where the circlip opens is okay. The circlip should compress when going through the splined section and pop open locking the axle in place when it reaches the larger opening at the bottom.
If you are installing a new axle, also check the length of the splined section as compated to your original axle. You may have the wrong part.
Old Jul 7, 2010 | 09:54 AM
The thing is, is that I have used the axle and transmission together before, then simply just swapped it into a different car with the same tranny and axle.
Old Jul 8, 2010 | 01:11 AM
chewyv's Avatar
pm4nudes
looks like you might have to just give up...
Old Jul 8, 2010 | 10:11 AM
Yea I'm gonna try a different approach.
Old Jul 8, 2010 | 10:47 AM
sleepinonacreeper's Avatar
what are trans and axle from? any pics of the end of your axle?
Old Jul 10, 2010 | 06:18 PM
Problem fixed, the shop gave me back the wrong axle that just happened to look exactly like mine... now onto the map sensor problem.
Old Jul 10, 2010 | 06:19 PM
The axle they gave me was 1/8 of an inch too short, thats what was goin on.
Old Jul 10, 2010 | 06:20 PM
mono6's Avatar
WOW that sucks..hopefully you didnt mess up your threads in the tranny..
integrainside
Oct 3, 2013 05:21 PM
grjr
Aug 23, 2012 04:12 PM
LS94tegra
Apr 19, 2008 11:59 AM
aziaticvang
Dec 27, 2007 05:22 PM
Feb 19, 2004 08:54 PM
