Morimoto Bi-Xenon Projectors
Cell: 832-428-2431 names Hanh
E-mail: sales@3bspec.com
PM or Email for package deals.
Prices start at $109.99 for the projectors.
The infamous Morimoto Mini Bi-Xenon Projectors!
Full bi-xenon projectors in a compact package. These share a similar "bolt-on" mounting feature as seen on the G1/G3 Bi-Xenon Projectors. They also have 4 mounting holes for traditional mounting methods. Perfect for amateurs looking to do a retrofit, while alleviating a lot of the major alignment problems that may arise. Get the best of both methods, by bolting in the projector for the initial alignment. Set the headlight in the car, use the headlight's original headlight alignment bulbs to perfect the lighting alignment, then finish the job by using support brackets of your choosing.
The Morimoto Bi-Xenon Projectors use the much more commonly found H1 bulb and can be setup to work with HID bulbs or with a halogen bulb if desired. We carry bi-xenon harnesses, H1 HID bulbs, H1 Xenon Halogen bulbs, Ballasts (35w, 50w, Slim 35w, and Matsushita/OEM Nissan on a limited basis), and projector shrouds to accompany these projectors.
Specifications:
- Bi-Xenon Projector
- Bulb Size: H1
- Max Depth: 5.35-Inch
- Max Height: 2.75-Inch
- Max Width: 3.14-Inch
- Lens Diameter: 2.5-Inch
95-99 Nissan Maxima R32 style headlight, E55 shroud.
Also carrying a number of different shrouds to go with these.
Cayenne Style Shroud
Gatling Style Shroud
GTi-R Style Shroud
Ocular S-Max Wide Style Shroud
Type 108 Shroud
Type 27 Shroud
Specifications:
- Bulb Size: H1
GTi-R Style Shroud
Type 108 Shroud
Type 27 Shroud
Making this a little easier so you can see what you're ordering:
http://shop.3bspecialties.com/3BSpec...motoHIDKit.htm
Email (sales-at-3bspec.com) with exactly the combination you're looking at and we can fire up a custom coupon code.
Hoping to see a small batch of FX-R projectors at the end of this month or early next month.
