diy 94 si courtesy lights :) mayb this will help
Old Jul 5, 2010 | 05:04 AM
spitra_01's Avatar
Default diy 94 si courtesy lights :) mayb this will help
First off i'm new to this form stuff but i wanta help so......
to start get ur lights mount them on ur door panels. i dont really like the oem lights so i made my own
now then run two wires from the lights on the door panel to the door? through the grommet
(i put some brush-on electrical tape so the wires don't stick out)
then under the kick panels
also i used some rca plug wire what better way to run two wires
on the drivers side or left side i did this
the drivers side by or in front of the kick panels under the carpet. you will find a wht/blu and a grn/blu for the driver side. wht/blu being positive and grn/blu being gnd. Also i use the wht/blu here for the passenger side 12v constant or positive.
tap the driver side light wires here
remove the door stills, the kick panels, the back seats on both sides if not done a ready. idk it seems kind of obvious this needed to be done for the next thing i did
well i took a remote amp wire i had found and ran i from the wht/blu under and through the wire stays? and grommets to the back seat through this
took a wire hanger straighten it out taped the end of the wire to it. pull it under and through the carpet to the other side
here in the pic above you will see a tap to the grn/red this is the grd for the passenger side. the wire u just ran is +12v. run both the wires to the passenger side kick panel to the light wires.
i used soldier and heat shrink for some of the connections, and taps, crimp to the lead out wires
i dont like electrical tape just comes off over time, so later u can fix a short.
put stuff back together
and done
Old Jul 14, 2010 | 05:26 AM
n0rmaL's Avatar
Default Re: diy 94 si courtesy lights :) mayb this will help
awesome write up man
Old Sep 19, 2010 | 12:53 PM
n0rmaL's Avatar
just did this today and it worked like a charm
Argentinakidd
Jun 17, 2018 05:47 PM
paowa
Mar 29, 2009 01:52 PM
jdmvtec@413
May 8, 2008 11:49 PM
taney
Honda Civic (2006 - 2015)
Jan 19, 2007 10:11 PM
