145whp hopegully
ok got a few mods just wonderin if i would be at 145 to the wheels use judgment guys ive never been to a dyno
short ram intake
ngk g power plugs
ngk 8mm wires
2.25 cat back
if im not there yet well damn header?? high flow cat??? would the addition of these add noticable power what are some other bolt on power makers
and is there a point to tune a ecu when a car has neither turbo or nitrous i cant grasp the concept behind it im sorry
short ram intake
ngk g power plugs
ngk 8mm wires
2.25 cat back
Let me get my crystal ball out, I see a head swap in your future, I see 40 HP per cylinder in your future. Sorry, getting tired, been up 24 hours. Exhaust system is a decent piece of help, every little thing you are talking about is little, but 10 littles adds up to a little more. The stuff you have mentioned is part of a tune up, lets think a little bigger now.
Though I would say GhostAccord will be making good power from his F more stylishly... haha!
https://honda-tech.com/forums/honda-accord-1990-2002-2/1990-2002-accord-faq-1664547/
scroll down to swaps.
Simply put: You don't need to tune for bolt-ons with these older Honda motors because frankly, they don't affect how the engine performs enough to warrant it (obviously this is different for newer engines like the K series which respond much better to simple mods. You can research that if your curious as well). The factory ECU can compensate and adapt to the bolt-ons and still work normally (and technically better).
Now when you start modifying things like cam(s), valvetrain, and compression you need to tune in order to optimize their operation together. The factory ECU has not been programmed (or tuned) to adapt to different cam durations or compression ratios because those are affecting how the engine operates at it's core. The engine may run, but not very well because the stock ECU doesn't know exactly what to do with the new readings it is getting.
Again, that's a simple explanation. Read up and enjoy your new-found knowledge. Good luck!
ak12gage
15
Apr 13, 2013 10:05 PM
blink_977
30
Nov 22, 2008 10:52 PM
Pistonhead
Jul 1, 2001 12:02 AM
