Need Help.. New build, starts but dies when warms up
Hi....
This is what i did...
1999 CRV.... ex.. OBD2B
Took the B20 out
Dropped in my New Build B17
B17 specs
11.8 CR (PR3 Pistons and 30 mill of the head)
0.50 mm over bore
Stage 2 cams with Ti retainers and dual springs
and some other small stuff
Converted to OBD1, using a Programmable P30/P28 ECU hooked up to crome
Just using a Basic P30 program with a PLX wide band and the narrow band output feeds the ecu
Distributor is OBD1 also
Using MSD 6 Box and coil
Manual AWD tranny.. un touched
After it idled for about 15 mins all heated up.. (idle was smooth)
it died
when trying to re start.. it spits, back fires.. let it cool... starts up again until hot...
The temp gauge doesn;t shoot right up just about normal operating temp..
No ECU CODES...
Also little quick trottle shots make it bog real bad and some times stalls and hard to restart..
Any help is Appreciated..
thanks in advanced..
Took the B20 out
B17 specs
0.50 mm over bore
it died
No ECU CODES...
I needed to unplug the injectors and crank it over to dry it out..
then i triple checked while i pluged the injectors back in..
ran so much better after.... i may have had inj 2 and 3 backwards...
using the obd2b harness and they come out at the same spot which would make it easy to do..
no way for saying for sure since i didn't check when i first un pluged them..
it still bogs a bit under driving conditions but it revs over 8000 hitting vtec...
i think i'm ready to give her a tune
IGNITER Module inside the dist, they are all the same try swapping it out with another one you/someone has around.
I'm using a MSD 6 box and coil..
It only bogs and pings on heavy accel from idle to 2000 rpm after that it;s smooth
thirsk66
13
Jan 17, 2023 08:07 PM
DAman9
Aug 5, 2013 07:17 PM
demo024
Engine Management and Tuning
Jan 31, 2011 06:33 PM
