What motor oil should I use for the tranny?
Old Jul 4, 2010 | 01:50 PM
hawjboieg6civic's Avatar
Default What motor oil should I use for the tranny?
I'm going to be swaping out my old civic motor to a new one but I'm not sure what kind of motor oil should I use for the tranny. The motor uses 5w-30 motor oil so should I use that kind of motor oil for the tranny too?
Old Jul 4, 2010 | 01:53 PM
civicsmoke's Avatar
Default Re: What motor oil should I use for the tranny?
id use honda mtf (assuming its a manual)
but when our cars were new honda recomended 5w30 or 10w30.
Old Jul 4, 2010 | 02:56 PM
dE.fUsEd's Avatar
Use only honda fluids FROM honda. Honda MTF for a manual, ATF for auto.
Old Jul 4, 2010 | 03:23 PM
bTwink's Avatar
I used Royal Purple Synchromax in my swap.
Old Jul 4, 2010 | 05:51 PM
thumper64's Avatar
syncromesh (GM, Pennzoil, etc) works well. It has a lot of zinc. Honda MTF is preferred.
Old Jul 4, 2010 | 09:38 PM
300whpej's Avatar
Honda MTF/ATF is about $7/qt in my area, which is pennies more than the other listed names. I'd go with Honda personally, especially since its something that get changed once a year if lucky.
Old Jul 4, 2010 | 10:18 PM
Iloveyourhonda92's Avatar
^^ same around here its about 7-8 dollars a qt... Honda is best!!.. same with oil filters as well!!
Old Jul 4, 2010 | 10:56 PM
nicefighter80's Avatar
"What motor oil should I use for the tranny?"
lolz
Old Jul 4, 2010 | 11:32 PM
NOFX's Avatar
H-T White Ops
lolz
Well, the fluid often recommended for Honda manual transmissions is called... motor oil. The fluid recommended by Honda (at least recently) is Honda MTF. 5W-30 works too though.
I personally use Amsoil Synchromesh. So far, so good. I don't worry about cost too much since it's not like I have to change it every month or anything.
Old Jul 5, 2010 | 05:29 AM
itsmejto's Avatar
lolz
Don't be an A.H.
The guy was asking a perfectly sensible question, some transmissions do use regular motor oil.
That's why he asked because he didn't know.
USE HONDA MTF OR ATF: RECOMENDED BY MOST.
Old Jul 5, 2010 | 11:43 AM
NOFX's Avatar
H-T White Ops
This is from a 1996 Civic manual.
Originally Posted by Honda
If Honda MTF is not available, you may use an API service SG or SG-rated motor oil with a viscosity of 10W-30 or 10W-40 temporarily. Motor oil can cause increased transmission wear and higher shifting effort, so you should have the transmission drained and refilled with Honda MTF as soon as possible.
Old Jul 5, 2010 | 11:52 AM
jmaze's Avatar
just dont use gear oil.
Old Jul 5, 2010 | 11:55 AM
MENEZ's Avatar
USE 10W-30 TILL U GET MTF OR IF ATUOMATIC ATF FROM HONDA
ptownsintegra
Sep 14, 2005 07:43 PM
ebelp
Jan 13, 2003 06:49 AM
egNYC
19
Nov 19, 2002 02:24 PM
Mikey
Oct 5, 2002 04:14 PM
Ri5e
Mar 16, 2002 07:17 AM
