everytime i accelerate i hear a knock
i was shaking the motor it doesnt move at all.. when i drive everytime im stopped and start to go i hear a knock comin from under kinda where the axle would be in the back of the motor
could be a failing inner constant velocity joint. i would check for any loose suspension parts. i had a knock like you describe when my radius rod was slightly loose at the knuckle.
it also maybe struts if they are blown, or suspension is not tight, my friend had this problem as well,alot of it was when he started off in first and it made a clunk/knock
themilman
Jun 26, 2006 05:43 AM
teg92
28
Mar 2, 2006 04:38 AM
