B16a EF swap wont start
I have a 90 civic si with a obd-0 b16a all plugs except ECT are connected, doesnt turn over but gets fuel and is throwing a code 6 im sure its because of the Fan switch on the thermo housing. When i turn the key i can hear the ignition switch clicking and also the starter clicking but just doesnt crank. The battery was completely dead but was charged when i tried cranking it. Don't know what it may be, im thinking its not grounded enough or a short somewhere?
Code 6: Engine Coolant Temperature (ECT Sensor).
Hook up it up, reset ecu, swap out for a sure-fire 100%-you-know-it's-working battery, make sure it's completely grounded, then try.
Come back with results.
swapped out for a good battery checked the grounds everything seems grounded properly and still no crank just the starter clicking. im going to go test the starter to see if its any good
unabonger
24
Apr 3, 2003 07:11 PM
