98 honda hx squeaking noise
Old Jul 3, 2010 | 03:15 PM
smd6942's Avatar
Default 98 honda hx squeaking noise
i don't know what the noise is but i have changed the belts and I was wondering if it could be the pulleys or what else it could be. It's very bothersome to drive with and I just want to fix it as fast as possible.
Old Jul 3, 2010 | 03:34 PM
infinitypro12's Avatar
Default Re: 98 honda hx squeaking noise
Does it make the sound when:
-Idle
-Different Speeds
-Different RPMs
-Forward
-Reverse
-Turning Left
-Turning Right
-ETC
Also, make, model, and engine will help others. Best of luck.
Old Jul 3, 2010 | 03:37 PM
smd6942's Avatar
sorry about that it is a 98 honda civic hx with a d16y5
the squeaking noise will happen all the time when idling and driving normal but when i put it in high rpm the sound will go away.
Old Jul 3, 2010 | 04:29 PM
vtec95dawg's Avatar
sound like a loose or glazed or wet soaked belt check alternator a/c power sterin belt
Old Aug 10, 2010 | 04:21 PM
smd6942's Avatar
all the belts are fine but i'm thinking it could be the pulleys themselves because the sound is louder at idle and at low rpm but at high rpm the car sounds a lot better. I'm really confused and i'm just trying to help my brother out by getting him a better sounding car . Or is it time to just scrap the piece of crap and just get a new engine.
Old Aug 10, 2010 | 05:01 PM
smd6942's Avatar
bump
Old Aug 10, 2010 | 06:19 PM
Former User's Avatar
Start by remove each drive belt one at a time to see which one is causing the squeaking.
whatmeow
Honda Civic (2006 - 2015)
Nov 28, 2018 03:31 PM
bloodyace05
Jan 26, 2016 03:10 PM
d124g0n
Jul 21, 2005 06:29 PM
droc327
Apr 26, 2005 12:54 PM
Sketch_hs
Jul 1, 2003 08:57 PM
