Q: F7 Rear Subframe Brace,
Old Jul 3, 2010 | 01:59 PM
LSWagovan's Avatar
Default Q: F7 Rear Subframe Brace,
i was wondering if anyone knew if a Function7 rear subframe brace off an eg will fit on a 91 crx. i dont wanna spend the money and have it not fit.
thanks in advance
http://www.jhpusa.com/store/pc/viewP...idcategory=170
Old Jul 3, 2010 | 02:03 PM
black0hatch's Avatar
Default Re: Q: F7 Rear Subframe Brace,
im guessing if it did fit a crx then the website would say it fits a crx. i think i remember seeing one modified to fit an ef but that was a long time ago.
Old Jul 3, 2010 | 02:06 PM
LSWagovan's Avatar
well i know a lot of stuff is interchangeable i just wanna know if anyone has had any experience.
Old Jul 3, 2010 | 02:11 PM
88Hatchy's Avatar
It doesn't matter if it fits or not. It's totally useless on an ED chassis.
Old Jul 3, 2010 | 02:22 PM
LSWagovan's Avatar
why's that?
and i dont have an ed chassis.
Old Jul 3, 2010 | 02:31 PM
88Hatchy's Avatar
Originally Posted by LSWagovan
why's that?
Subframe braces only make a difference when the swaybar is mounted to the subframe. '88-'91 Civics and CRXs that have swaybars, have them mounted to unibody below the trunk/hatch.
If you don't have an ED chassis then why are you posting in this section?
EDIT: I see that you have a wagon..
Old Jul 3, 2010 | 10:43 PM
DCRB's Avatar
why not just get the asr kit....
http://www.amazon.com/ASR-Swaybar-Re.../dp/B002ELW83U
Old Jul 3, 2010 | 11:14 PM
rexracer626's Avatar
Originally Posted by DCRB
agreed!!
Old Sep 15, 2010 | 07:36 PM
Function7's Avatar
thanks in advance
Our brace will fit a 88-91 CRX/Civic although we did not plan on it from the get go (it was really designed for the EG/DC chassis). Several of our customers have installed them (check on B20VTEC.com) and installed aftermarket sway bars on the subframe brace (like in a later Civic/Integra model).
A few holes (4 total) need to be drilled on the subframe to attach the backplate of the subframe brace and the rest is bolt on.
-A
Old Sep 15, 2010 | 09:23 PM
asianflava's Avatar
Which swaybars work with this brace?
Old Sep 16, 2010 | 02:58 PM
Function7's Avatar
Almost any OEM or aftermarket subframe mounted sway bar will work with our brace. The OEM 92-95 Civic or 94-01 Integra (including the ITR) sway bars will fit.
Our brace comes with multiple mounting holes that accomodate brackets of different sizes. We do know that all the common brands of sway bars do work with our brace (ST, Progress, ASR, and several others... and if you can't find a bracket that fits our brace, you can get the universal sway bar brackets from us or directly from Energy Suspension.
-A
Old Sep 18, 2010 | 05:55 AM
hush22's Avatar
Hes getting techincal. The wagons chassis code is an EE.
I see your point none the less.
okc
12
Apr 6, 2010 04:44 PM
SINISTR
Nov 13, 2006 10:26 PM
ALLOUT CL55
Apr 7, 2006 08:51 PM
MR-MUGEN
Jun 11, 2005 01:02 PM
EF_LSVtec
Sep 20, 2002 09:57 AM
