Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Towing, hitch class, trailer rental, I have no idea WTF I'm doing
Old Sep 14, 2002 | 08:31 PM
MaddMatt's Avatar
Default Towing, hitch class, trailer rental, I have no idea WTF I'm doing
OK, so I want to tow next weekend to Roebling. I have access to my uncles F150 which should be up to the task. He tells me it has a class 2 hitch which is rated up to 7,000 lbs. I then find out on the U-haul website that the class 2 hitch is really 3,500 lbs. Anyone know for sure?
Anyone have good luck renting a U-haul trailer?
Old Sep 14, 2002 | 08:37 PM
MaddMatt's Avatar
Default Re: Towing, hitch class, trailer rental, I have no idea WTF I'm doing (MaddMatt)
Hmmm. Looks like class 2 is only 3500 lbs. Guess I'm calling my uncle tomorrow to confirm it's a 2.
Might be driving to GA after all.
Old Sep 14, 2002 | 09:02 PM
.RJ's Avatar
.RJ
Matt... i havent really located a tow vehicle for RR either, so it looks like i'll be driving as well. I'd like to meet up with the NC gang near raleigh and caravan down...
RJ
Old Sep 14, 2002 | 09:20 PM
Drew M's Avatar
New User
You need a Class III hitch to tow a car. Class III are rated at 5,000lbs. The F150 *should* have a 10,000lb capacity. A Class II is up to 3500lbs but you will be well over that with the car and trailer. I can guarantee you that a U-Haul car trailer weighs close to if not over 2000#. Add another 2500 or so lbs for your car and you are tearing that 4-bolt hitch off the frame of the truck.
A Class III hitch for that truck can be had for under $200 however. U-Haul uses a sliding tongue/hydraulic brake system for the trailer so you wouldn't need to worry about any wiring for it either.
FYI - Class IV is the 7,500lb rated series (12,000lb with a weight distribution system)
Old Sep 14, 2002 | 10:18 PM
civicrr's Avatar
Default Re: Towing, hitch class, trailer rental, I have no idea WTF I'm doing (Drew M)
The F150 is a 1/2 ton truck. It is not rated to tow 10k even with a weight distrib. hitch. It will, depending on engine, tranny & rear end gears tow up to 8800 with a wd hitch. As Drew mentioned, you should be able to pick up a bolt on class III or class IV hitch fairly cheaply.
The following info was taken from the Draw-tite website.
Class II = Up to 300 lbs. TW, Up to 3,500 lbs. GTW
Class III = Weight-Carrying 500/5000 (usually - some are 600/6000)
Class IV = Weight-Carrying 1k/10k
[Modified by civicrr, 11:19 PM 9/14/2002]
Old Sep 15, 2002 | 05:48 AM
Drew M's Avatar
New User
Default Re: Towing, hitch class, trailer rental, I have no idea WTF I'm doing (civicrr)
Sure it will - I can go grab my 1988 Bronco owner's manual and scan the page that says it has a maximum GVW of 10,000lbs. A Bronco is just a short wheelbase F-150. Yes I know that the GVW includes the weight of the truck but that is still part of the towing capacity since it has to "tow" itself along with the trailer.
Old Sep 15, 2002 | 06:04 AM
J28S's Avatar
New User
Look for the GCWR (Gross Combined Weight Rating) of the tow vehicle. This will give you the maximum weight of the vehicle and the maximum weight the tow vehicle can haul combined.
Old Sep 15, 2002 | 06:07 AM
Drew M's Avatar
New User
Default Re: Towing, hitch class, trailer rental, I have no idea WTF I'm doing (J28S)
Damn that's what I meant - GCWR. Thanks Starnes!
Old Sep 15, 2002 | 06:55 AM
civicrr's Avatar
OK, if you want to use the GCWR, but that is cheating.
Out of curiostiy, I went to Ford's site. For 2002, I found GCWR from 6500-13500 & trailer weights from 2000-8800. These numbers varied according to engine, tranny & rear end gears. Just FYI.
[Modified by civicrr, 8:08 AM 9/15/2002]
Old Sep 15, 2002 | 07:18 AM
Drew M's Avatar
New User
*Most* F150s were shipped with the towing package so it is a safe bet his F150 has it.
Combined weight is cheating? How?
Drew - Whose Bronco is right at its 10,000lb combined limit when it is towing to a race but with the weight distribution system can still cruise comfortably at 80MPH.
Old Sep 15, 2002 | 07:38 AM
civicrr's Avatar
I read it to mean that the truck could tow 10k. OK, it isn't really cheating as long as you let people know that it includes the weight of the tow vehical.
BTW, what WD system are you using? Sway control? Trying to get ideas for when I can actually afford a enclosed trailer. Thanks.
Old Sep 15, 2002 | 07:44 AM
MaddMatt's Avatar
OK, found out a little more.
The truck in question is a '92 F150 in outstanding low mileage condition. It has "only" the 5.0 V8 and a trans cooler (so I assume that means towing package). The hitch was installed in '92 after it was purchased. My unlce is 100% sure they told him it was a class 2 and rated to tow 7,000 lbs.
So, any chance that in '92 the rating system was different and a class 2 could handle that much back then?
I suppose I could get a tow dolly, but I'd REALLY like to rent a trailer instead.
Old Sep 15, 2002 | 07:52 AM
J28S's Avatar
New User
Yes, if it has a V8 and an OEM tranny cooler, then it most likely has the "Tow Package". BUT, the tow package would most likely include a tow hitch...then again back in '92 maybe they had a different theory....
If the hitch is rated at 7,000 lbs, then I don't think you'll have a problem towing you car on a trailer.
Old Sep 15, 2002 | 07:55 AM
Drew M's Avatar
New User
I use the Draw-Tite system.
http://www.drawtite-hitches.com/WD/sway_control.htm
The one we have is the older one that does not have the second cams running from the spring to the trailer (no pictures of it on the site). We also have the friction sway control. It is noisy but damn it works. I towed at 80MPH through NC and SC on the way to CMP and the truck never swayed. Keep in mind that a Bronco is a short wheelbase and it sways when it doesn't have a trailer attached.
Matt:
My guess is they were talking combined weight and there was a misunderstanding. That truck probably weighs about 4000lbs. Add the 3500lb capacity of the Class II and you have your 7500lbs.
Old Sep 15, 2002 | 09:25 AM
r2x's Avatar
r2x
Matt - Were is the hitch ball? On the bumper, or attached to the frame (like the one on the Jeep)?
D
Old Sep 15, 2002 | 09:29 AM
r2x's Avatar
r2x
Default Re: Towing, hitch class, trailer rental, I have no idea WTF I'm doing (r2x)
OK, I just went and looked on both the Jeep and the Tahoe and there is a fancy little sticker on both hitches saying the weight limits. Can your uncle see if there is one of those on there? Also, if it's not the 2 inch receiver, that might be a clue too.
r2x ~ who'd loan you the Jeep, but it doesn't have a tag on it.
Old Sep 16, 2002 | 05:58 AM
JoelG's Avatar
Matt,
If it turns out to be a class II hitch, consider using a dolly instead of a trailer. Your car on a dolly should be well under 3500lbs. Another thing to consider is triangle to RR is about the flattest tow you could do so lack of power will not be a problem.
Joel
Old Sep 16, 2002 | 06:13 AM
krshultz's Avatar
I have some zip ties you can borrow.
Old Sep 16, 2002 | 06:20 AM
whitney's Avatar
Never believe the sticker on the hitch. Without checking the owner's manual first. It's really the lesser of the two numbers. My class III hitch says "5000 w/o WD, 10000 w/ WD", yet the manual says "8000 w/o, 12000 w/". I'm less than 5000#, w/o WD, so I don't really care. "Trailer? What trailer?"
Matt - rent a 2-car carrier and I'll tow both of us down there. And yes, my truck could do it
(edit - clarification)
[Modified by whitney, 10:23 AM 9/16/2002]
SpeedyAmy
Meets & Events
Aug 9, 2016 08:39 AM
H22AFerio
Northwest
May 15, 2011 12:11 PM
Lo-Buck EF
Oct 25, 2002 08:29 AM
