Steering wheel shakes when braking.
at what speed are you braking?
most likely its your rotors that are warped. same problem happen to me when i'm slowing down from like 70mph on the freeway, anything on the streets slower than 35mph i didn't feel any vibration.
i would just change out the rotors and pads for new one.
i have also heard that the front cross member rod bushing can be the problem as well.
More than likely it is warped rotors, take a close look at all steering components too, tie rods, tie rod ends, ball joints, steering rack mounts. If you change out the rotors, make sure you torque the wheels on properly with a torque wrench. It is believed that most warpage is caused by improper wheel installation. Its worth the extra couple of minutes of your time and patience. I am leaning towards also suggesting that you only get OEM parts.
kevcha711
Jun 2, 2010 09:45 PM
teletekman
May 3, 2006 09:15 AM
Ef Whore
Nov 26, 2002 07:04 AM
