d16a6 obd0 to obd1 question please help me
Old Jul 2, 2010 | 03:12 PM
CRXguy_88's Avatar
Default d16a6 obd0 to obd1 question please help me
ok i have a complete a6 swap with everything ecu dizzy and so on so on.. found a crx shell that is wire for obd1 and i know that my swap is obd0.. WHAT WOULD I NEED TO DO TO MAKE THIS WORK TOGETHER? any help would be great.. possibly to take my crx's body slash engine harness to run on the other shell? or shud i just convert the motor. please help me
Old Jul 2, 2010 | 03:21 PM
lunalink's Avatar
Default Re: d16a6 obd0 to obd1 question please help me
it would be WAY EASIER just to convert the motor obd1..what do you mean by the CRX being wired for obd1?
Old Jul 2, 2010 | 03:31 PM
CRXguy_88's Avatar
the guy with the shell got it and the person before him f'd up the wiring when it was obd0, so he took out dash and completely rewired the car for obd1 with the motor he had.. took his motor out and im wanting to put a di6a6 (obd0).. what shoul i do and how would this be done
Old Jul 2, 2010 | 04:11 PM
ASO's Avatar
ASO
obd1 injectors obd1 dizzy
Old Jul 2, 2010 | 04:17 PM
EFRue57's Avatar
obd1 dizzy doesn't have the correct bolt pattern. you can use an obd2 dizzy and the bolt pattern is the same as the obd0 dizzy, then just repin the dizzy connector with an obd2 one and it works just the same. looks cleaner in the end.
Old Jul 2, 2010 | 04:30 PM
CRXguy_88's Avatar
i was told a d15b7 dizzy will work.. so all i need is obd1 injectors and dizzy?
shadhman
Jun 23, 2008 12:43 PM
B16A CRX
Feb 5, 2007 03:52 PM
lsvtec90
Nov 22, 2005 09:01 AM
dpw41285
Mar 30, 2004 07:10 AM
skud_dusty
13
Apr 25, 2003 11:51 PM
