DC Struts on EF questions
Old Jul 2, 2010 | 02:15 PM
EF_Tovi's Avatar
Default DC Struts on EF questions
Well i might be buying some GC/koni from a dc for cheap soon and i was wondering what was all needed to make them fit. I know you'll have to use eg/dc front forks and i read that the rears bolt up just fine so i just wanna make sure i get all the info i can get before i buy these.
thanks in advance.
Old Jul 2, 2010 | 02:46 PM
lunalink's Avatar
Default Re: DC Struts on EF questions
like you said all you need is either the eg or dc forks
Old Jul 2, 2010 | 02:55 PM
EF_Tovi's Avatar
alright thanks man. so this should go pretty good for me since hes throwing the eg forks in too
Old Jul 2, 2010 | 03:07 PM
lunalink's Avatar
yup!
whats the price if i may ask?
Old Jul 2, 2010 | 03:11 PM
lunalink's Avatar
here are some pics of the CRX i sold recently with GSR suspension
Sorry for the big oh pics. but just letting you know it would fit good. ( better than my Tokicos LOL )
Here's how my sedan sits with the same suspension
Old Jul 2, 2010 | 03:22 PM
EF_Tovi's Avatar
Originally Posted by lunalink
yup!
PM'd
Old Jul 2, 2010 | 04:32 PM
BrayzieEF9's Avatar
you need eg front forks
Old Jul 2, 2010 | 04:55 PM
90_EX_Civic's Avatar
Originally Posted by BrayzieEF9
you need ef front forks
the ef forks won't fit. the diameter for the shock is bigger then the ef.
plus you'll be sitting about an inch higher then normal.
Old Jul 2, 2010 | 05:07 PM
BrayzieEF9's Avatar
they do fit just wont be as low when you adjust your coilovers and the correct forks to use is eg forks
EDIT I just noticed when i got home i put ef instead of eg when i was typing on my phone my bad
Old Jul 2, 2010 | 05:10 PM
BrayzieEF9's Avatar
oh yeah if your planning on riding slammed,just get the correct suspension for your car
Old Jul 2, 2010 | 05:40 PM
no prob.
also forgot to add. op, hope you are not swapping over a whole complete stock integra suspension over? now that won't fit, i've tried. the rears will barely fit, and you can forget the fronts. it's way to tall.
Old Jul 3, 2010 | 11:10 AM
specie's Avatar
I have eibach pro springs and koni yellows from my old '94 integra. All I need to make the springs/struts fit my '90 Crx Si is just to get eg front forks?
Old Jul 3, 2010 | 11:40 AM
mitsubishiv5's Avatar
who said eg/dc/ek suspension doesnt make your car low? look at my ****. bunch of misinformation. onlything that may be different is "spring height" or spring weight. thats about it.
Eg/DC/eK struts are similar to the ef, only thing different is the diameter of the strut to the fork. shock travel is the same as well as or close to same spring height!
im running function and form For eg using eg forks.
Fern413
Apr 3, 2008 07:04 PM
. M i c h a e l
Dec 3, 2005 12:41 AM
Integra_B18B
Dec 1, 2004 06:47 PM
wuhungsixxx
Aug 7, 2001 04:50 PM
