exhaust vibrating?
Old Sep 14, 2002 | 05:48 PM
civic-cpe's Avatar
Default exhaust vibrating?
i have a cusom cat-back on my car for several months, but have never noticed something until a friend asked me a few days ago. my car was started and she went to the trunk to get something. she asked, "is your exhaust supposed to be vibrating so rapidly?" i went out and looked at it and noticed that it was vibrating very rapidly and a lot also. if you put your feet on the tip, you can really feel the vibration. is this normal?
Old Sep 14, 2002 | 07:52 PM
VTECorona's Avatar
Default Re: exhaust vibrating? (civic-cpe)
My dc exhaust does that too. Its more of a rapid shaking and not a vibration. I think it stops after it gets warm but I'll have to get back to you on that
Old Sep 14, 2002 | 07:59 PM
vtec.dc2's Avatar
lower rpm increase exhaust movement - like around 600-800rpm...
stock exhaust use spring-tesnion bolts at mid-pipe to muffler pipe connection to reduce the vibration, most aftermarket don't have spring tension bolts, so connection is more solid - therefore more vibration.
if all the connections are torqued to specs and theres no rattling, theres not much else to be wrong..
Old Sep 15, 2002 | 07:54 AM
civic-cpe's Avatar
Default Re: exhaust vibrating? (97RedTegGSR)
not too sure if it does that after the exhaust is warm, but i think it does. actually, it should be warmed up already since i was driving for a few hours at that time. there was stop and park, but from the time i ignited the car til the time my friend told me to look, it was a 25 mile drive already, plus idle time.
Old Sep 15, 2002 | 07:59 AM
civic-cpe's Avatar
Default Re: exhaust vibrating? (vtec.dc2)
low rpm increases exhaust movement? really? didn't know that. prolly that's the reason since it was idling when i look at it. well, obviously, or how else would i be able to see it.
mine is a custom exhaust, so no connections. it's a straight 2.25" pipe from the cat to the exhaust inlet. there's no resonator either. so, can this be the prob?
does it vibrate so much as i am driving? cause i think it looks pretty odd if it does. anyone seen it vibrating while driving?
scrooge
Honda Civic (2001 - 2005)
Sep 7, 2008 06:17 PM
Jordans95si
Aug 6, 2005 07:58 AM
94AccordCoupe
18
Feb 12, 2004 11:36 AM
gstintegra92
Aug 31, 2003 07:46 PM
nijia555
May 20, 2002 06:22 AM
