Suspension & Brakes Theory, alignment, spring rates....
omni coils not low enough
Old Jun 30, 2010 | 06:05 PM
92cxhatch169's Avatar
Icon2 omni coils not low enough
so ive got some omni full coils and the back still has a lot to go but the front is all the way down and the bumper is still about 4 inches off the ground. anyone know a trick to make it lower? all adjusters are all the way down.
Old Jun 30, 2010 | 06:52 PM
98civdx's Avatar
Master Detailer
Default Re: omni coils not low enough
Remove adjusters.
Old Jul 1, 2010 | 05:09 PM
kevinm1981's Avatar
remove the adjusters off full coilovers??? bad advice...
Old Jul 1, 2010 | 05:54 PM
98civdx's Avatar
Master Detailer
how?
Old Jul 1, 2010 | 06:40 PM
kevinm1981's Avatar
cause it will ride like **** most likely. i have koni/gc springs and no adjusters and it rides pretty much like having no suspension.
350lb front and 250lb rear. hella soft springs.
Old Jul 1, 2010 | 06:43 PM
kevinm1981's Avatar
if you remove the adjusters on one peice coilovers then what will the spring sit on? i think you mean for slip on coils.
Old Jul 1, 2010 | 08:11 PM
98civdx's Avatar
Master Detailer
Most coilovers have 2 adjusters, not just one. I do belive omni power uses 2.
One the coilover you have posted you cant, because there is no where for it to sit. But on some you are able to.
There will be the top adjuster and the lower used to lock the upper, by removing the upper you can drop it a bit more.
I removed both adjusters on my skunk2 slip ons, casue the spring to sit on the factory perch, about 2.5 inches lower then before, i know where your coming from.
Op do you have 2 adjusters or one?
Old Jul 1, 2010 | 09:09 PM
i was told that the omni's can thread into the shock body if that makes sense
brndon076
Honda S2000
53
Apr 24, 2012 03:25 PM
JasinC19
Suspension & Brakes
15
Feb 28, 2012 07:46 PM
delsolbro
Suspension & Brakes
Apr 12, 2011 02:39 PM
HondaSPEC99
Aug 7, 2010 06:53 PM
Aphrodavid
Nov 27, 2002 12:42 PM
