tach signal ?
just baught a 2000 ek dx d16 with no tach in the cluster i had a tach in my old car i just popped the cluster read a diagram n installed it i havent done any resurch on the ek but i was just wondering if i could hook the signal wire up to the dizzy somehow.. or should i do the same thing that i did with my old beretta?
if you're talking about adding an aftermarket tach... there is no need unless you frequent the track.
grab a compatible OE cluster that came with a tach (EX, Si, maybe even CRV...) and it's all plug and play. no need to run wires, just remove the DX cluster and install the EX/Si cluster and you'll have a working tach.
To answer your question, there's a solid blue tach signal wire behind the cluster, or if you want to run it to your dizzy, connect it to the negative side of the coil. Either way...
averyvm
Jul 15, 2008 01:21 PM
khhoa
Jul 11, 2008 04:11 AM
