SRS module removal
Old Jun 29, 2010 | 07:10 PM
CDelgado220's Avatar
Default SRS module removal
So I finally got around to dismantling the car b/c inspection is coming up and need this SRS out before I go get it inspected but I ran into an issue.. I can't remove these 3 bolts to take out old module.
I've used elbow grease & an 18V battery powered drill but didn't do the job. I'm going to recharge the batteries and try again tomorrow. Any advice on any other methods to remove it? Is there a special tool to remove this...maybe. Thanks gents.
~Christian
Old Jul 2, 2010 | 10:21 PM
PilotOnDubs's Avatar
Default Re: SRS module removal
you should be able to remove them w/ a torx t30 socket bit.
dont use a drill, cause that can strip the head. if the head is stripped, then you will have to keep drilling it out completely
i use this one by hand w/ a 3/8 hand ratchet...
http://www.thetoolwarehouse.net/p-55...ool-42580.aspx
Uncle Willie
Apr 25, 2016 08:48 AM
Liquidgsr
Apr 26, 2006 10:20 PM
ih8danoles
Apr 21, 2003 12:21 PM
iam7head
Sep 25, 2002 07:05 AM
type autox
Jan 21, 2002 06:55 PM
