95 eg ex kick panel power lock wires?
Old Jun 29, 2010 | 05:53 PM
mcgruff's Avatar
Default 95 eg ex kick panel power lock wires?
im TRYING to install a viper 5002 alarm and am getting held up at the door lock part. i found the blue connector by the fusebox that everyones always talking about (see i searched!) and theres a female 2p connector taped to it, not connected to a male, that has my suspect green/red and green/white wires. (the honda wiring diagram makes it seem like the green/red and green/white wires go to the power lock module in the door.... is that where the relays are? the wiring diagram for the alarm is telling me to splice between the switch and the relays... which brings us back to the connector. i dont even know how to test it since its on the ground side... im afraid to ohmmeter it and mess up the module in the door... in short, i just want to make sure these wires are appropriate... thanks in advance for any direction.
p.s. it doesnt seem possible to tap into the wires directly at the door switch because theres no room in the harness to get it through the door
Old Jul 1, 2010 | 06:15 PM
ShiroX's Avatar
Default Re: 95 eg ex kick panel power lock wires?
That plug is already tapped into the door lock/unlock wires in the door. All you have to do is connect the lock wire to green/wht and unlock to green/red.
If you want a plug and play install...go to the junk yard and find the female connector, attach wires and plug it in.
Old Jul 5, 2010 | 06:06 PM
fcm's Avatar
fcm
Old Fart
If you want to test them, just ground them, [touch to ground]. 94
csmith21
Audio / Security / Video
Feb 16, 2011 09:56 AM
JaySauce
Apr 18, 2009 05:11 PM
JaySauce
14
Apr 17, 2009 09:56 PM
slow motion
Aug 17, 2004 12:57 AM
spunky424
Mar 2, 2004 04:10 PM
