Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Anyne know how to change window REG.
Old Jun 29, 2010 | 03:00 PM
si_motor_spt's Avatar
Default Anyne know how to change window REG.
Hey all, any one know how or can direct me to how to change a driver side window regulator...My sisters window wont roll up or down,motor dosent make any noise....
Old Jun 29, 2010 | 03:15 PM
It Wasn't Me's Avatar
Default Re: Anyne know how to change window REG.
Is it just the driver's side that doesn't work, or is it both sides?
Are you sure it's the power window motor and not a fuse, relay, or the power window switch? Have checked or tested those?
Here's a quick photo-guide I made a while back for removing the door panel. Not the best, but it should do. You'll find the power window motor in the door.
You don't have to remove the tweeter, but it does make things a bit easier. Just carefully pry it off. It's only held on with a couple clips.
I recommend checking and testing the other items before you go ahead and replace the motor for the window. You should test the motor, also. Just disconnect it and run a lead from a 12v battery to it. It'll either go up or down. If it doesn't work, replace the motor.
Old Jun 29, 2010 | 06:04 PM
Rob.C's Avatar
Mind going into more details on how to do this? Also I believe there's two bolts involved that you can only unscrew when then window is down at a certain point, how would one go about rolling the window down to unscrew them?
Old Jun 30, 2010 | 04:33 AM
chawski's Avatar
if its definately the window regulator, I have a spare one if you want it for cheap (its just collecting dust...make an offer and its yours). I replaced it thinking that was the problem and it turned out to be the switch in the door.
Old Jun 30, 2010 | 10:15 AM
Rob.C's Avatar
I was looking at this guide.
http://www.civicforums.com/forums/36...vic-coupe.html
Old Jun 30, 2010 | 11:49 AM
thanks guys for all this great info, i'll keep u guys posted when i do it and try to take some pics of it.....
Old Jun 30, 2010 | 12:14 PM
Originally Posted by Rob.C
Ah! Yeah, I totally overlooked those bolts. My bad!
Thanks for the link, I added it to the FAQs.
Old Jun 30, 2010 | 04:21 PM
Rob.C's Avatar
Still not sure how I would go about testing the motor and removing those screws if the motor doesn't work.
Old Jun 30, 2010 | 05:23 PM
Why do you need to remove those screws to test the motor? You don't. You disconnect the clip and apply 12v power, as shown and described in the photo.
The glass can still be removed from the power window assembly, even if the motor doesn't work.
Old Jun 30, 2010 | 07:14 PM
Rob.C's Avatar
Okay I think I got this down, thanks.
Old Jul 3, 2010 | 05:20 PM
Rob.C's Avatar
Finally got around to do this today and I got the motor to work. Only fuse I checked was the one for power window under the hood and it looked fine, I even replaced it with my spare. Whats next to check?
Old Jul 3, 2010 | 11:06 PM
Did you check (test) the Power Window Relay?
Old Jul 4, 2010 | 04:31 AM
Rob.C's Avatar
Amazing, while doing some more google searching I found out about the lock out switch, I've owned this car for a year and one month now and I never looked at the buttons on my side. To think since day one all I had to do was push that button and plug it up, was unplugged when I first opened the door.
Sorry, but to think I went a whole year not being able to roll that window down and it was a damn 5 minute fix.
I can't wait to go for a drive.
Thanks for the help.
Old Jul 4, 2010 | 09:26 AM
LOL!
Well.. we all brainfart from time to time.
Happy 4th!
Old Jul 12, 2010 | 01:37 PM
Rob.C's Avatar
Just when I was enjoying my window it messes up again. I was installing my window deflectors and was rolling the window up and down and now the window just goes down. Testing with my other motor and it only goes down with the switch as well.
Pauly321
Dec 2, 2016 12:15 PM
GsRrrr
Jun 14, 2011 04:02 PM
streetlights
Dec 5, 2008 10:06 AM
jdm_bones
Jul 19, 2007 12:16 AM
lahight
Sep 6, 2002 09:09 PM
