Accord wit h22 swap (HEADER QUESTION)
I had purchase headers for my h22 and the headers i purchase was for a 94 prelude. Now they don't fit my 94 accord 4 Dr cat converter or straight pipe which i am planning to do a engine swap into my Accord.
Now, how or Wat is the best way i can make this all work out or would i have to order headers for my 94 accord? PLEASE help
Thank You
Thank You
you have to modify the H22's downpipe to fit your accord's catback, or vice versa. One way of getting arond that is using the H22 downpipe, CAT, nad a 90-93 accord's catback which will be a bolt on apparently. There was also another bolt on way using a 98 Prelude SH headers which comes with an adaptor for something but I forgot how that goes.
yea i was gonna use my aftermarket headers with the 98 prelude cat converter, but the only thing is dat the ludes converter is alittle shorter then my accords by 2-3 ins. don't know if that will make a difference!!!
i do have a whole new exhaust for my 5 Gen accord. Still nothing! h22 header down pipe is a whole lot different from Accords down pipe!!!
I have a JDM Mugen H22A header for sale.. should work nicely with your setup.. check it out
http://hondamarketplace.com/showthread.php?t=2795805
did u order it as for n accord or prelude? Cause i ordered my headers for a 94 prelude Vtec engine... i just need to know how to order n wat to order so it will fit my stright pipe!
I notice you're Hmong. I'm Hmong as well.
I still got my No Name brand header that got modified to fit Accord catback. PM me.
Yea im hmong man..lol but yea how much u planning to get for those headers? Btw im from Blaine, MN so it dont seem like u too far from me (stp). yea
my accord is da 5th gen CD5!!! 94 Ex.. yea man we should get together n race sometime wen i get my swap done. but sht do u have pix of the heaers can u post it so i can c it! If u dont mind!!!
Yeah, I'll get pics of it soon. I'm always kicking it at University every Fri & Sat night, so I'll see you there when you get done.
Don't forget to check my youtube channel for new vids; I post up new vids every weekend from races I do.
yea man dats koo. Yea im jux waiting on the headers now but yea i did c ur youtube vids they aren't bad at all man knowing how accord is! Dats y I'm doing a CD5 h22 swap too cause too many ppl think Accords aint sht n r too into Hatches!!! Yea i saved u as friend so u should c my request. Yea jux send me pix if the headers n if i like it then i'll take it!! let me know!
Generally you will just take your car down the your local exhaust shop and have your exhaust modified to fit. Probably cost you $20-$30, we do these all the time.
here's what worked for me.
1st I ordered a header for a 98 Prelude Vtec
2nd I ordered one of these Honda Accord 90-93 Test-Pipe
3rd I installed the header and found it was much longer then my OEM F23
Measured gap between the down pipe flange (3 bolt offset triangle) and the beginning of the cat back exhaust (3 bolt triangle flange). It was about 6 inches of space
I Then had test pipe cut down and shortened at a local welding/machine shop to fit so it looked like this
worked like a charm. this was my way since i would not sacrifice to cutting up my RS*R cat back
good luck
mike
good luck
mike
