smokes like a freight train
Old Jun 29, 2010 | 02:10 PM
FEDONV8's Avatar
Default smokes like a freight train
I got my car tune like a week ago. and on that day i was driving back it was a 5hr drive. Dispite i didnt check the oil after the car got off the dyno i thought the car would be fine. midway back i probably got on it like twice and the car started to smoke white smoke. I think the tune was kind of shitty because he only did 3 pulls. the ar was 11.70 and i thought that was kind of lean. i have no motor work down at all just put on a very nice turbo kit. Anyway when i got home that day i had no oil in the motor. do yall think its a ringland or a broke piston. and if so what route would u take to put it back together. i want to drive the car really bad i do have a spare bottom end sitting up.
Old Jun 29, 2010 | 02:21 PM
4g4dcruisin's Avatar
Default Re: smokes like a freight train
hmm..ok.
So you didnt check the oil before a 5 hours drive, and you have a turbo?! If you got white smoke, your head gasket is blown. But that doesnt make any since you were able to drive it that long while smoking.
Old Jun 29, 2010 | 02:42 PM
FEDONV8's Avatar
right it go me back home it had oil before i left because the car rode fine and i am a maintance guru. i thought i just change my oil like two weeks ago. the car does make a noise but not knock more like a exhaust leak noise. but yeah strange i made it back home. the car even has blow by also. lol it even smokes sitting still.
Old Jun 29, 2010 | 02:44 PM
rustanghunter's Avatar
wait, what?
Old Jun 29, 2010 | 02:53 PM
You thought you changed your oil? So were you confused? haha
Old Jun 29, 2010 | 03:34 PM
KWayRacing's Avatar
i had oil in my car 2 weeks ago sorry i change my oil with 10 30 royale purple
Old Jun 29, 2010 | 04:30 PM
wait your a maintenance guru and cant remember if you changed your oil?
Old Jun 29, 2010 | 04:38 PM
FEDONV8's Avatar
instead of yall helping me about my problems yall bashing me about a **** *** oil change. if u want to kill my post go ahead i have dont more wrench turning than any of u **** heads.
Old Jun 29, 2010 | 04:39 PM
well twist another wrench and change your head gasket
Old Jun 29, 2010 | 05:42 PM
.Manny.'s Avatar
Touching My Member
Leakdown Test it guru. /thread
Old Jun 29, 2010 | 05:59 PM
D16SiHatch's Avatar
oh snap lol
Old Jun 29, 2010 | 06:02 PM
.Manny.'s Avatar
Touching My Member
h3 d3ff m4d!! da tooning didnt go so well and nao he haz a blownz moter
Old Jun 29, 2010 | 06:30 PM
FEDONV8's Avatar
it is leaking oil thru the gasket but maybe i shouldnt have post maybe i should have just gotten my friend to just check it out.
Old Jun 29, 2010 | 06:32 PM
DCRB's Avatar
LAWLZ
Old Jun 29, 2010 | 06:56 PM
CRX_nut's Avatar
Hey man all jokes aside we all are "maintanence guru's" in our own respect, but i had the same problem and it was a blown head gasket and it warped the head and cracked the block. i only drove it maybe 50 miles after that happened. But I would have the head pressure/vacuum checked. and get your block checked. You may have to go to a thicker head gasket and stronger head bolts. Hope this helps.
Old Jun 29, 2010 | 09:39 PM
.Manny.'s Avatar
Touching My Member
All BS aside man, a leak down test is your best bet, it will tell you exactly where the problem is. Don't know how to perform one or have the tools? Google it or search here and maybe rent or buy the tester. Do you have a compressor?
Old Jun 29, 2010 | 10:06 PM
FEDONV8's Avatar
Thanks I do have a compressor thanks for the info. Why did the motor last so long til I got home it was bone dry. Was the tune ok the car made 270 hp on 10psi. But I'm glad I got back home safely the car was pretty quick I must say. But when I left my friends master tech at Honda. And the car was tech inspected for the road. I drove the from ms to Huntsville ala with no problem. It's might funny that oil leaks out after the dyno run.
Old Jun 30, 2010 | 06:38 AM
Old Jun 30, 2010 | 07:16 AM
cybernetictoast's Avatar
That s**t is funny. I just came here cause I'm having a similar problem minus the boost, but I have oil in my engine so never mind.
Old Jun 30, 2010 | 11:22 AM
FEDONV8's Avatar
Man I don't know why people think they r perfect stuff happens all the time don't think just because u change ur oil today and top it off the next couple of days. U might hit something and not know about and u don't have oil. It happens to people all the time. I going to take the motor and trans out and put a head gasket and a new bottom end and called it a day. I'm wiring tucking it while every thing is out.
Old Jun 30, 2010 | 11:25 AM
Believe me, if i was to hit something that hard, i'de pull over and check.
Besides, your low oil indicator doesnt work or what?
Old Jun 30, 2010 | 11:39 AM
.Manny.'s Avatar
Touching My Member
Dude, leakdown test it before tearing it apart! Don't assume you know what is wrong with it, test and be certain.
Old Jun 30, 2010 | 11:49 AM
I know theres oil in my car because I have an oil pressure gauge. I got rid of my idiot light. It could be low but if I had none I'd also have no pressure.
Old Jun 30, 2010 | 02:14 PM
FEDONV8's Avatar
What if it making a rattling Sound and it has blow by I means the car sucks oil now.
Old Jul 1, 2010 | 10:31 AM
your still trying to run it? dont. sounds like maybe more than a head gasket, sounds like you ran it out of oil and drove it a long distance, did you do any tests?
